Hello!
I have a layout with hierarchy like:
TOP
--Cell_A
--Cell_B
----Cell_C
I am attempting to place some Cell_D at the position of Cell_C using copy_tree and Cell_C.insert(), however when I use cell.insert() it gets positioned at Cell_B, the parent.
All I can provide is pseudo-code, but I start with this:
from SiEPIC.utils import get_layout_variables
TECHNOLOGY, lv, ly, cell = get_layout_variables()
And then use copy_treeon Cell_D, and call Cell_C.insert(Cell_D.cell_index(), Trans(0, 0))
And Cell_D gets placed at Cell_B rather than Cell_C. If I perform the same action on some Cell_D and insert at Cell_A or Cell_B, it works as expected - this is only not working if I'm inserting at a cell that is not at the TOP level.
I'm clearly missing some understanding of how hierarchy origins/transformations work, and I'm wondering if you can help with the solution for placing cells at the right position no matter how deep in a hierarchy they are?
Thanks so much!
Hi @spark_aeon
I'm a bit confused as the code should be that:
(not the "CellInstArray"). This should definitely create an instance of Cell D inside Cell C. If it doesn't something is wrong with Cell_C (maybe it does not really refer to Cell C?). Without some working code I cannot say more.
