Is there any way to programmatically convert an OASIS file to a PNG image file? I know that within the UI I can open OASIS and then do File>Screenshot, but I'd like a way to do if from within Python if possible. Thanks!!!
There is a related discussion ongoing: https://www.klayout.de/forum/discussion/1711/screenshot-with-all-the-layer-and-screenshot-only-one-layer#latest
From there you can learn a lot about Python coded image generation scripts and it has a fancy version of a screenshot tool
If by "Python" you mean the Python module on PyPI, it also has a
LayoutView
class and can bascially do the same.Matthias
Thank you for your response Matthias! I should have explained my issue better. We will be running on a system without graphics support so are unable to open the Klayout UI. I'd like to be able to make calls to KLayout from the command line to perform the oasis to image conversion. Does Klayout expose this functionality outside of the UI? Thank you!!!
I'd advise to use the Python module. It provides a stripped-down version of the
LayoutView
class which can render OASIS to PNG without a graphics device.Just do
There is a demo web component (https://pypi.org/project/kweb/) that uses this technique to render layout on a HTTP server interactively through a WebSockets connection.
Hi chrisl,
I hope the attached sample script from my toolbox will help you understand.
I have tested the code on Mac, Linux, and Windows 10.
Note: the [-c|--conf <KLayout's config file>] option is now effective. Replaced the attachment.
Sample Run
Kazzz-S
Cont.
How to reach LayoutView::load_layout()
Visit the URLs below sequentially:
1) https://www.klayout.org/klayout-pypi/
2) https://www.klayout.de/doc-qt5/code/index.html
3) https://www.klayout.de/doc-qt5/code/module_lay.html
4) https://www.klayout.de/doc-qt5/code/class_LayoutView.html
5) https://www.klayout.de/doc-qt5/code/class_LayoutView.html#method136
Cont.
Fixed a problem in Windows and re-attached the ZIP file (2024-08-06).
Sorry about the inconvenience.
Cont.
I found and fixed a fatal bug (cell hierarchy level is not checked), then re-attached the ZIP file (2024-08-07).
Sorry about the inconvenience once again.
Hi @sekigawa,
thank you very much for providing these scripts! It is very much appreciated
Just for my understanding - the fatal bug is not something inside KLayout, isn't it?
Hi @Matthias,
The bug was not inside KLayout; I misused an API function.
Incorrect:
Correct:
Kazzz-S
Very good. Thanks for the explanation!
I will check it out! thank you so much @sekigawa and @Matthias!!!
@sekigawa I made a small change to remove the requirement for the layer file as I only have OASIS to work with and the images convert with no issue! Thank you so much! The converted image looks the same as the one imported via KLayout as hoped for!
Traceback (most recent call last):
\gds_to_image\invKazzzS.lyp (errno=2) in LayoutViewBase.load_layer_props
File "D:\gds_to_image\oas2png-new.py", line 453, in
main()
File "D:\gds_to_image\oas2png-new.py", line 440, in main
ProcessOneOASISFile( configdic, item, count )
File "D:\gds_to_image\oas2png-new.py", line 278, in ProcessOneOASISFile
layoutview.load_layer_props( LayerPorpFile )
RuntimeError: Unable to open file:
Hello, I got this error, where is invKazzzS.lyp file?
You need to provide your own *.lyp for OASIS files.
If you want to trace the above sample run, please use the attached files.
Just wanted to follow up on this - @sekigawa - Is there way on the .conf file to setup a dither pattern that can be importer into oas2png, for example the current .conf file has a bunch of configdic options that get imported (background-color etc.) but the dither pattern and layer color is automatically cycled? Thanks!
Hi @Nanobot,
I searched the klayout config file for
dither
as follows.These
*-dither-patter
tags are related to the marker DB and not the ordinary layers.The
dither-pattern
tag seems unsupported; therefore, your last line,-->
, won't work.If you edit your .lyp file to include layer colors and dither patterns explicitly, you can get them in output PNGs.
Otherwise, the default patterns will be automatically cycled.
That's my understanding.
Kazzz-S
Ok, Thanks Kazzz-S for the quick response, is that a limitation of the python script? Just trying to see if there is a way to do a global constant dither pattern irrespective of the layer. Perhaps @mathias can help with some insight?
I went through all the options on the conf file and curious if there is a document/link somewhere that has list of configfic keys that I can pass. @sekigawa @mathias
Hi @Nanobot,
The following are related to your interests.
Kazzz-S
