Region constructor
edited January 2025 in KLayout Support
For Region constructor, I want to ask whether we can specify the method to construct it? I mean like in Python, we can use keyword to restrict them, then we can use specific method to construct our classes.
Currently, I think the region constructor in KLayout select the way to create the class by determining the input automatically. But when I wrap the pya.Polygon into my own class, then I create my own polygon and use region to combine them, and the constructor failed. Here is the code, you can reproduce such problem.
class MyPolygon:
    def __init__(self, pts):
        self.obj = pya.DPolygon(pts)
if __name__ == '__main__':
    polygon1 = MyPolygon([pya.Point(0, 0),
                          pya.Point(0, 20),
                          pya.Point(20, 20),
                          pya.Point(20, 0),
                          pya.Point(0, 0)])
    polygon2 = MyPolygon([pya.Point(0, 0),
                          pya.Point(0, -20),
                          pya.Point(-20, -20),
                          pya.Point(-20, 0),
                          pya.Point(0, 0), ])
    print(polygon1.obj)  # (0,0;0,20;20,20;20,0;0,0)
    print(polygon2.obj)  # (-20,-20;-20,0;0,0;0,0;0,-20)
    print(type(polygon1.obj))  # <class 'klayout.pyacore.DPolygon'>
    print(type(polygon2.obj))  # <class 'klayout.pyacore.DPolygon'>
    region = pya.Region([polygon1.obj, polygon2.obj])
The error information are seen like below.
  • class MyPolygon:
    vs
    class MyPolygon:
            self.obj = pya.Polygon(pts)
  • edited January 2025
    Oh my god, is this mean that for region stuff, we can not use float coordinates? Is this mean that if we want to deal with nm, we need to use dbu as coordinate first, and to make integer coordinates, and then we convert to um? Seems this is not convenient. It will take a lot of effort!
  • The constructors from Polygon to DPolygon and from DPolygon to Polygon are provided, but not between an array of them, which is the root cause.
    Therefore, the two cases below work if you want to keep pya.DPolygon in class MyPolygon.
    I think f2650C.py would be practical.
    f2650B.py
    class MyPolygon:
                              pya.Point(0, 20),
                              pya.Point(20, 20),
                              pya.Point(20, 0),
                              pya.Point(0, 0)])
                              pya.Point(0, -20),
                              pya.Point(-20, 0),
                              pya.Point(0, 0), ])
        #region = pya.Region([polygon1.obj, polygon2.obj])
        region = pya.Region(polygon1.obj)
        #                   ^^^^^^^^^^^^ Single DPolygon; not an array of DPolygon
    f2650C.py
    class MyPolygon:
                              pya.Point(0, 20),
                              pya.Point(20, 20),
                              pya.Point(20, 0),
                              pya.Point(0, 0)])
                              pya.Point(0, -20),
                              pya.Point(-20, 0),
                              pya.Point(0, 0), ])
        dbu    = 0.001
        _dbu   = 1.0/dbu
        region = pya.Region([pya.Polygon(polygon1.obj*_dbu), pya.Polygon(polygon2.obj*_dbu)])
  • Yes, got it. Thanks
