It seems convex partitions, is what I have to spent a little bit too much time in the recent days. The e-beam software, supports polygons as input now, were the shots are then nicely placed, but the polygons need to be convex. The initial results from the previous thread were a start, but the partition was not utilizing the capability too well.
I then look a little bit around and found this library for partitioning polygons, and the results seemed promising (https://github.com/ivanfratric/polypartition). Especially the Hertel-Mehlhorn algorithm seemed to work quite decent. I tried to implement a version in Ruby that is not yet smart enough to use the longest edge first (which seems to be heuristically the better one to merge), but it kind of works. Perhaps somebody finds it useful, or can improve it to be smarter or faster in the future.
class DRC::DRCLayer
def decompose_HM()
result = RBA::Region.new
self.data.each do |p|
if p.is_convex?
result.insert(p)
next
# Get initial triangulation
current_region = RBA::Region::new(p)
triangles = current_region.delaunay
triangles_a = triangles.each.to_a
changed = true
while changed
changed = false
# Try each pair of triangles
(0...triangles_a.length).each do |i|
((i+1)...triangles_a.length).each do |j|
merged = RBA::Region.new
merged.insert(triangles_a[i])
merged.insert(triangles_a[j])
# Perform merge
merged.merge
# Check if result is a single convex polygon
if merged.count == 1 and merged[0].is_convex?
# Update triangle list
triangles_a.delete_at([i,j].max)
triangles_a.delete_at([i,j].min)
triangles_a.push(merged[0])
changed = true
break
break if changed
result.insert(triangles_a)
return DRC::DRCLayer::new(@engine, result)
polys = polygons("Holes")
#polys.data = polys.data.delaunay
polys.decompose_HM.output(1006)
Also if Klayout ever supports some of the Hertel-Mehlhorn algorithms or even some optimal partition algorithm like Keil and Snoeyink,
could be useful, but perhaps not very fast.
And a slightly improved version that changes the way it iterates over the triangles, checks for triangles to touch each other before merging and also calles the GC every 1000 runs, because before KLayout would crash.
Hi @gyger,
That is actually very interesting. You seem to have done some research and maybe you can share some publication links? You can also send information privately through the contact mail address if you wish.
I found this nice overview page: https://bjpcjp.github.io/pdfs/math/polygon-partitions-ADM.pdf, but a more detailed overview is appreciated.
I am aware that my implementation is a pretty stupid one. I was mainly interested in the trapezoid decomposition as that is the basis of the MEBES format I am utilizing myself. There is a constrained Delaunay triangulation based on Chews second algorithm, but I assume this is not what you are looking for. However, as I understand, Delaunay triangulation can serve as a basis for Hertel-Mehlhorn, so that is appears a viable implementation path. What do you think?
I am aware there is CGAL or other libraries which contain lots of awesome algorithms. But frankly, it's always a pain to integrate third-party libraries - some may not be thread safe, others don't specify anything in that respect, some are not compatible with certain systems, some are written in Fortran (which I won't ever touch again after my old days with VAX/VMS) and debugging is never fun. I prefer having the original publication and being able to implement it myself. Usually there is a lot of overlap with existing data structures I can reuse and I can take care of things like thread safety.
Update: I would be specifically interested in a quality convex decomposition that guarantees rectangular pieces when possible, ideally maximizing the aspect ratios of the pieces. Another thing I am interested in is an algorithm that finds the maximum rectangle that fits inside a polygon.
Hello Matthias,
sorry for responding so slow. I came only across now.
The Hertel Mehlhorn Algorithm is original published as Fast triangulation of simple polygons (https://link.springer.com/chapter/10.1007/3-540-12689-9_105).
I found a lot of O’Rourke, J. books very nice on Computational Geometry.
1) O’Rourke, J. Art Gallery Theorems and Algorithms; The international series of monographs on computer science; Oxford Univ. Press: New York, NY, 1987.
Put online by the author: https://www.science.smith.edu/~jorourke/books/ArtGalleryTheorems/
2) O’Rourke, J. Computational Geometry in C, 2nd ed.; Cambridge University Press: Cambridge, UK, ; New York, NY, USA, 1998. https://www.science.smith.edu/~jorourke/books/compgeom.html
3) Handbook of Discrete and Computational Geometry, Third edition.; Tóth, C., O’Rourke, J., Goodman, J. E., Eds.; CRC Press: Boca Raton, 2017.
Preprint online: http://www.csun.edu/~ctoth/Handbook/HDCG3.html
They usually always reference the original publication.
Yeah, I think the constrained Delaunay triangulation is a good starting point for the Hertel-Mehlhorn algorithm.
About libraries, I absolutely agree that these algorithms are probably best integrated into the code base of KLayout.
On the updated message, I am currently unable to answer this, but I will keep looking.
With maximizing aspect ratio, I guess you mean, to make them as equal as possible.
I think they call that a fat object in geometry. Perhaps somebody else reading this has more experience there.
Hi @gyger,
thanks for these pointers. I will take a look.
I basically feel that A* search can be tailored to my needs, but I need to investigate that. Anyway, thanks a lot.
