Hi, I need to make an open path of a donut, so I need to draw an arc...I coverted to PCell a box and I selected ARC option. The properties of ARC PCell are two radius but in my case, is only an arc, so both radii are the same...My question is that in the edges of the arc appears a little square, how can I remove such little square? I don't want that the square appear in the layout...
those are just handles by which you can adjust the arc's parameters. They won't appear on the mask.
To remove them, either convert the PCell to a static cell or disable "Show PCell guiding shapes" in File/Setup, page Display/Cells.
