First of all, Thanks for building this amazing tool. I love it's super easy functionality and usage.
I have been using this product mainly for GDS viewing and came across "Trace Net" feature. I don't have LVS net information or any labels defined for net, but i simply want to trace connectivity by clicking at one point in design which can take Metal and via information from layer stack and highlight connected path/polygons.
Is this possible? If yes, i am not able to do this with defining metal and via information in layer stack yet. Is there any trick?
- Vaibhav
Hi Vaibhav,
the "Trace Net" feature provides exactly the functionality you look for.
To set of a layer stack, open the net tracer dialog and click on the "Layer Stack" button in the lower left part of the dialog.
There is more documentation here: http://www.klayout.de/doc/manual/net_tracing.html.
I have a design with a LVS-reported three-net short fairly well up the hierarchy. When I run Trace-Path against two of the nets, it thinks for a while and reports that they're not connected. When I run Trace-Net against one of those nets, it thinks for a while and highlights shapes on both nets.
By the way, thank you for a very useful tool - and did I say, fast!
At your convenience I would like to discuss a few things with you that are probably too sensitive for the forums. I believe you have my email address from my registration here.
- phred
Hi phred,
you can contact me through the mail listed on the "Contact" page. I'm interested in a testcase that allows me to reproduce the problem. Basically a connection should be reported if the net tracer propagates along the short. Everything else is a bug.
