i want to calculate the antenna effect for a few different layouts.
Right now i calculate the gate first and then i iterate over ever poly gate to define the metal and via layers, code below. The tiling is to reduce the memory for further calculation, i only have a 32bit computer and without i run into a memory issue.
My problem now is the time. When iterate over every polygon form region1 and check interacting parts with the metal region it's very slow. Is there a other and faster way to do something like this because right now i need a few hours for a small layout with around 10k gates.
region1 = RBA::Region::new()
tp.threads = 4
tp.input("a1",RBA::Region::new(topcell.begin_shapes_rec(active layer index))
tp.input("a2",RBA::Region::new(topcell.begin_shapes_rec(poly layer index))
tp.output("x1", region1)
tp.tile_size(@topcell.bbox.width, @topcell.bbox.height)
tp.queue("_output(x1, (a2.merge).select_interacting(a1))")
tp.execute("1")
region1.each do |polygon|
## get the gate area
gate_area = 0
gate_region = RBA::Region::new()
tp.threads = 4
tp.input("a2",RBA::Region::new(polygon))
tp.output("x1", gate_region)
tp.queue("_output(x1, a2.merge & a1)")
tp.execute("1")
gate_area = gate_region.area
region_metal = RBA::Region::new()
region_via = RBA::Region::new()
tp.threads = 4
tp.input("ground",RBA::Region::new(polygon))
tp.input("via",RBA::Region::new(topcell.begin_shapes_rec(via layer index))
tp.input("top",RBA::Region::new(topcell.begin_shapes_rec(metal layer index))))
tp.output("x1", region_metal)
tp.output("x2", region_via)
tp.queue(<<END)
var bx = ground & via;
_output(x1,(top.merge).select_interacting(bx) );
_output(x2, bx )
END
tp.execute("1")
Thanks for help
Dominik
Hi Dominik,
I have some doubts whether this code is correct. Where is the gate area used? Maybe I am missing something - if you use Markdown markup (four blanks in front of code lines), the code will be easier to read.
Basically a specific rule like the antenna check is definitely something that needs to be coded in C++. Ruby will be much too slow for that purpose.
I also think that tiling is not a valid approach, since it will cut polygons apart. That way the area is not computed correctly for polygons touch polygons from neighbour tiles.
that's what i expected, but thank you for your help.
I am aware of the problem with tiling that's why i use the whole chip as tile size. But this will clean the memory after i finished my calculation, without i will run into a memory issue.
Regards
Dominik
Hi Dominik,
the reason why the tiling processor helps is that it will free memory immediately while in Ruby, the garbage collector will do this occasionally. You can however, enforce memory release with the "_destroy" method.
Looking at your code reveals some optimization potential in Ruby too. Specifically the merge method is called many times on the whole layer. You should do this once outside the loop. You can also utilize region queries to confine the computations to the vicinity of the gate net.
Here is some sketch for an optimized code:
i tried to use destroy before, but not _destroy that's why I used tiling.
But anyway when i want to use your code with _destroy my application is crushing down, without i have no problem
I use QT to create an Interface, is there some influence in the background?
Thank you for your help
Dominik
Hi Dominik,
I have not tested the code myself since your version wasn't complete. Maybe you can paste or publish your real version in some other way so I can try that.
Anyhow, _destroy is not mandatory, so without it should do too. But in general, _destroy is doing the same thing that the garbage collector would do - but when you want it to happen, not when the garbage collector chooses to do that. That will render some more reproducibility.
Without your full code I can't say whether there is some interference. And I can't debug anything. Please don't let me guess.
