Hello all,
I have upgraded KLayout from 0.24 to 0.26.4.
Before I upgraded, I could use Cntr+S which stands for "show as new tap"
But after I upgraded to 0.26.4, when I press Cntr+S, warning window poped up and it says, Keyboard shorcut is ambigious
How can I solve this problem?
It`s really annoying without this shortcut to use it.
Thank you in advance ![]()
PS) Sorry for wrong category, I don`t know how to change it to general discussion
I admit that is a slight inconsistency. The "Show as new top" feature is present twice: once in the cell list context menu and once in the "Display" (aka "zoom_menu") menu.
To avoid this conflict, you should undefine the shortcut in the cell list context menu like this:
Are such changes "nonvolatile" or must this be done every
session?
Hi Jim,
they should be persistent. If not I apologize: it's a bug then. Right now, the problem is the twofold binding and Ctrl+S is the default for one of them. So you can't change the other to Ctrl+S without creating this conflict. But just not setting the second to anything should do the job.
I am still hoping that the bindkeys will someday be made
completely and arbitrarily overwritable (a bindkey save and
load to / from an external file). The "special" status of the
built-ins, I think is the root of the problem.
Thank you very much!
it works perfectly
