**This has been solved* Hello, I am getting the following error in klayout anytime I try to create an instance:
internal error: ../ ../ ../src/db/db/dbTrans.h1672 mag > 0.0 was not true
It popped up first when I accidentily magnified an instance by x180, but even after undoing this mistake it won't let me continue.
I cannot create any new instances or use existing ones without this error message appearing.
Anyone know how to fix this?
180 should not cause this problem. But scaling with a negative value or zero may.
And I was not able to reproduce the problem is a persistent way. I can trigger it when I scale with "0", but it is not persistent.
