Hi everyone:
I'm working on a project that requires heavy loading on simulation. The Klayout is working on the same PC that runs the simulation tool.
Sadly, the PC sometimes froze due to the simulation program's instability, and I had to force restart the PC.  If I didn't save the layout before the simulation, I would lose the layout. Sometimes I remember to save the layout, and sometimes I forget. So I want to implant the autosave ability with a python script.
Here is my code after surveying community :
import threading
import time
counter = 0
class Timer:
    def __init__(self):
        self.start = time.time()
        self.period = 0.1  # period of update in seconds
        self.last_update = self.start - self.period
        self.current = None
    def update(self):
        self.current = time.time()
        if self.current > self.last_update + self.period:
            pya.QCoreApplication.processEvents()
            self.last_update = self.current
class RepeatedTimer(object):
    def __init__(self, interval, function, *args, **kwargs):
        self._timer = None
        self.interval = interval
        self.function = function
        self.args = args
        self.kwargs = kwargs
        self.is_running = False
        self.next_call = time.time()
        self.start()
    def _run(self):
        self.start()
        self.function(*self.args, **self.kwargs)
    def start(self):
        if not self.is_running:
            self.next_call += self.interval
            self._timer = threading.Timer(self.next_call - time.time(), self._run)
            self._timer.start()
            self.is_running = True
    def stop(self):
        self._timer.cancel()
def auto_save():
    # Save the layout prior to exporting, if there are changes.
    global counter
    counter += 1
    print(f"{counter} autosave check.")
    if mw.manager().has_undo():
        mw.cm_save()
    layout_filename = mw.current_view().active_cellview().filename()
    print(f"Autosave to {layout_filename}.")
    if len(layout_filename) == 0:
        raise Exception("Please save your layout.")
def main():
    # autosave every 10 min
    rt = RepeatedTimer(600, auto_save)  # it auto-starts, no need of rt.start()
    timer = Timer()
    try:
        while True:
            timer.update()
    finally:
        rt.stop()
main()
The thing is if I run the script from the startup, it blocks every other script I made to run from the startup, and the macro development window is disabled. Besides, it is very CPU-consuming. Any suggestions?
BR
Ernest
@Ernest you cannot let a script run infinitely in the background. The Qt UI main thread is blocked while you run scripts and that has severe consequences.
The way to do that is a QTimer object that delivers regular events out of the main thread's event loop.
The basic way to use a timer is this (taken from https://www.klayout.de/forum/discussion/1688):
But honestly: there are other solutions for stopping another process from interfering with your work - such as going into a cloud with the simulation tool, using ulimits if you're on Linux etc. You cannot patch every working tool you're using to support autosave. Plus IMHO autosave is ugly. It overwrites your file and imagine if the freeze happens during autosave - in that case even your file is gone.
@Ernest Thanks for the code ... I took the liberty to format it properly.
Regarding the default location ("BackUp.gds") I'd propose to use a full path. Otherwise the file gets written to the current directory which is not well defined.
Is there any other way to understand that changes exist other than
manager().has_undo()after saving?cm_savedoes not change the undo state, and neither can turn off the action manually. Can we reset the undo state after saving, or do we have something else to look for?Hi @crizos,
LayoutView#clear_transactionsshould clear the undo buffer.Matthias
Thank you Matthias, it worked.
For the first part, is there any other way to understand that changes exist other than
manager().has_undo()after saving? Not only by code but also withFile->SaveorCtrl+S. For example, I see a[+]in the tab title; is there any way to check for that? Or a diff way that what I am seeing is the original GDS file I opened?Well, yes. Individual cell views can be checked using
CellView#is_dirty?(https://www.klayout.de/doc-qt5/code/class_CellView.html#method33). This flag falls back to false if the layout is saved from the user interface or programmatically viaLayoutView#save_asorcm_save.Matthias
Thank you Matthias, that is what I was looking for.
Chris
I have a follow-up question on this one:
Let's say we reach state A, we are saving in that state (by any means), and we do some actions B and C, which are first required to be done in a saved environment but not save the outcome of these actions.
We then revert back to state A by code (mainly adding and removing text objects are these actions, to be exact). There is no difference from the starting state A, but
is_dirty()naturally has turned totrue.Is there a way to manipulate this flag by code; when we revert the actions, also to reset the state of that flag?
Chris
Hi @crizos,
No, there is no way to directly manipulate "is_dirty".
If you have saved the layout in state A, you can basically revert back to state A by reloading the layout by using "LayoutView#reload", then the dirty flag should be cleared.
But I wonder what your application is. If you need to create temporary objects, e.g. for net naming, maybe it is easier to create a copy of the Layout object and then add the texts (provided your layout isn't too large). That does not spoil your loaded layout state.
I tried reloading, but I usually edit large files and I'm trying to avoid reopening/reloading which is the reason for reverting/deleting staff. Can you give an example of your suggestion for copying the layout? Would e.g. the text labels be visible to the viewer of the copied object? Can I keep the file in memory, and display only the copied version, and reset it when I am done?
Edit: I believe you suggesting keeping a backup of the layout in state A, doing everything that has to be done from now on and then doing something like this at the end, e.g.:
# reaching state A
layout_bck = pya.Cellview().active().layout().dup()
# irrelevant actions here
# getting back to state A
pya.Application.instance().main_window().current_view().show_layout(layout_bck, False)
Please let me know your thoughts,
Chris
Hi Chris,
I meant I wonder why you need to manipulate a live layout. That is like if Word was changing your text to show you spelling errors (contrived example maybe). I though that in order to highlight some error regions for example, you could display a copy and then delete it once the user has reviewed the errors.
Can you maybe explain you use case? I think I am able to make some suggestions if I understand the actual problem you are trying to solve.
Actually, you helped me with your last suggestion to copy the
Layoutobject and reset that one when I have to revert to a checkpoint. I was misguided that I must use theCellViewsomehow since that has theis_dirtyflag. Your directions have helped me a lot. The example I attached seems to fit in what I am trying to achieve.Thank you again,
Chris
