I'm starting to accumulate and now reuse a lot of low
level (custom transistor) layouts in my work and it's
getting a bit crowded in the file pile.
I have seen that there's some kind of "use a second
GDS file as a library" capacity. I've found it a bit clunky
to copy between open layouts so have been just exporting
"done" devices to their own individual GDS file. Those
seem like my two options for corralling a herd of funky
one-off device layouts for a series of future products
(a lateral PNP is a lateral PNP, unless it's in a LM158).
But thought I'd kick off a discussion of how other people
(if anybody out there is going down the same or similar
road) like to approach this aspect of design management.
Basically libraries are a simple way to organize layouts.
There is a simple way to use GDS files as libraries:
~/.klayout/librariesfolder (you can also stash it somewhere else and use$KLAYOUT_PATHto define multiple places KLayout looks for). On Windows the place isc:\Users\you\KLayout\libraries.You will then find the new library under the LIBNAME you gave it when saving in the library browser (by default below the cell list).
Some things are worth noting:
I found this very helpful, do you think the information here could be put onto the "About Libraries" page? https://www.klayout.de/doc/about/about_libraries.html
Specifically, because I didn't have the libraries folder in my Klayout folder, I wasn't sure if I had done something incorrectly when saving my previous gds with a lib filename. But after finding this post, I figured I should try out manually creating the \libraries folder and placing my gds there. The library name didn't seem to match with what I had put in the "Library name" when Saving as, but at least it's there now to use
It took me a while to find this post, but I'm definitely glad it's here .
I agree with the above. Updating the "About Libraries" documentation with the information discussed in this forum thread would be very helpful.
Further, what would be really helpful is if for a given library name, Klayout can pull all top-level cells from all GDS files saved with the same library name. Right now, it seems if you have multiple GDS files in
~/.klayout/librarieswith the same library name, only one of those GDS files will mapped to that library name. This would be handy when you have multiple designers contributing to a single library. Each designer can work in a separate GDS file which then contribute to the unified cell library.I'd take this a step further and maybe look at
making a "CAD administration for non-sysadmins"
cookbook. We all want to jump ahead to the fun,
but running the Zamboni first (and maybe at half
time) does improve the game-play.
If it spread to encompass schematic and simulation
point tools so much the better. I look ahead to the
day when klayout, xschem and ngspice become
an integrated design platform like SDA1.0 and that
layer, wants this.
Hi @kurisu,
I have created a ticket for this request: https://github.com/KLayout/klayout/issues/2147
@dick_freebird People are working on this, but as always, it's a matter of funding. In this case, it's public money. Company sponsorship is hard to find for such an endeavor.
Thanks @Matthias ! Appreciate it!
