Hi Mattias,
I am using on PEX extraction and stuck on this error.
Not sure why min_b=0 in region.delaunay works but extraction keeps failing.
And, in your opinion, when dealing with non-orthogonal shape in PEX, these statements are correct (assume we don't care the R result) ?
1. min_b=0 is better than min_b=0.3
2. tessellation is better than squarecounting
Sorry I try to read online but still cannot understand the functions completely.
Since I cannot post too much information here. I hope you can reproduce the error using limited information below.
I installed klayout 0.30.9 in linux system.
from typing import *
import klayout.db as kdb
import klayout.pex as klp
tech1 = klp.RExtractorTech()
tech2 = klp.RExtractorTech()
m1 = 10
m2 = 20
v1 = 15
for l in (m1, m2):
m = klp.RExtractorTechConductor()
m.layer = l
m.resistance = 1
m.algorithm = klp.Algorithm.Tesselation
m.triangulation_max_area = 0
m.triangulation_min_b = 0
tech1.add_conductor(m)
m.triangulation_min_b = 0.3
tech2.add_conductor(m)
v = klp.RExtractorTechVia()
v.cut_layer = v1
v.bottom_conductor = m1
v.top_conductor = m2
v.resistance = 1
tech1.add_via(v)
tech2.add_via(v)
points = """-13025.42800 -33338.54100
-13127.95900 -33236.01000
-13132.73200 -33240.78300
-13135.91400 -33237.60100
-13026.13600 -33127.82300
-12923.60500 -33230.35400
-12920.42300 -33227.17200
-13022.95400 -33124.64100
-13014.99900 -33116.68600
-13011.81700 -33119.86800
-13016.59000 -33124.64100
-12914.05900 -33227.17200
-12923.60500 -33236.71800
-13026.13600 -33134.18700
-13029.31700 -33137.36900
-12926.78700 -33239.89900
-12936.33300 -33249.44500
-13038.86300 -33146.91500
-13042.04500 -33150.09700
-12939.51500 -33252.62700
-12949.06100 -33262.17300
-13051.59100 -33159.64300
-13054.77300 -33162.82500
-12952.24300 -33265.35500
-13012.70100 -33325.81300
-13115.23100 -33223.28300
-13118.41300 -33226.46400
-13015.88200 -33328.99500"""
points = points.split("\n")
points_kdb = []
for p in points:
x, y = p.split()
points_kdb.append(kdb.Point(round(float(x)/0.001), round(float(y)/0.001)))
polygon = kdb.Polygon(points_kdb)
region = kdb.Region([polygon])
geo: Dict[int, kdb.Region] = {m1: region}
x1, y1 = -13133, -33238.8
x2, y2 = -13015,-33120
port_a = kdb.Point(round(x1/0.001),round(y1/0.001))
port_b = kdb.Point(round(x2/0.001),round(y2/0.001))
vertex_ports: Dict[int, List[kdb.Point]] = { m1: [port_a, port_b] }
polygon_ports: Dict[int, List[kdb.Polygon]] = {}
rexer = klp.RNetExtractor(dbu=0.001)
try:
network = rexer.extract(tech1, geo, vertex_ports, polygon_ports)
print(f"PEX min_b=0 PASS: {network.to_s(with_coords=True)}\n")
except Exception as e:
print(f"PEX min_b=0 ERROR: {e}\n")
try:
network = rexer.extract(tech2, geo, vertex_ports, polygon_ports)
print(f"PEX min_b=0.3 PASS: {network.to_s(with_coords=True)}\n")
print(f"PEX min_b=0.3 ERROR: {e}\n")
try:
m1_delaunay = region.delaunay(max_area=0, min_b=0)
print(f"REGION min_b=0 PASS\n")
print(f"REGION min_b=0 ERROR: {e}\n")
try:
m1_delaunay = region.delaunay(max_area=0, min_b=0.3)
print(f"REGION min_b=0.3 PASS\n")
print(f"REGION min_b=0.3 ERROR: {e}\n")
ERROR: src/db/db/dbPLC.cc,543,false
PEX min_b=0 ERROR: Internal error: src/db/db/dbPLC.cc:543 false was not true in RNetExtractor.extractERROR: src/db/db/dbPLC.cc,543,false
PEX min_b=0.3 ERROR: Internal error: src/db/db/dbPLC.cc:543 false was not true in RNetExtractor.extractREGION min_b=0 PASS
REGION min_b=0.3 ERROR: Internal error: src/db/db/dbPLC.cc:543 false was not true in Region.delaunay
Hi @jinxtopcs,
thanks for the nicely prepared test case. This problem looks like a numerical issue. I'll try debugging the problem.
Just fyI: a better place for bug reports is the GitHub issue tracker: https://github.com/KLayout/klayout. Bugs reported there can be tracked for easily and connected to pull requests.
