Starting a Ruby GUI w/out showing the Klayout GUI
edited April 2015 in Ruby Scripting
I am writing an application where I would like to use Klayout-supplied behavior but I don't need the normal Klayout user interface. I have written my GUI in
QT Designer as a .ui file that I load this way:
  module MyMacro
    include RBA
    HERE = File.dirname(__FILE__)
    UI   = File.join(HERE, '..', 'data', 'framebuilder5.ui')
    ui_file = QFile::new(UI)
    ui_file.open(QIODevice::ReadOnly.to_i)
    dialog = QFormBuilder::new.load(ui_file, Application::instance.main_window)
    ui_file.close
    dialog.show
I don't know how to keep the Klayout GUI from appearing without taking away my
application's GUI capability. Can anyone suggest a solution?
My version of Klayout is 0.23.9 compiled with Qt 4.8.5 and Ruby 1.9.3 on RedHat Linux 5.6 (sorry I cannot update my OS).
Dave
  • edited May 2015
    Hi Dave,
    The "-z" command line option is your friend. You can use it with "-r" to run a script without starting the application:
    Here is a sample:
    include RBA
    dialog = QDialog.new(Application.instance.main_window)
    dialog.setWindowTitle("Dialog Title")
    dialog.resize(350, 300)
    grid = QGridLayout.new(dialog)
    windowlabel1 = QLabel.new(dialog)
    windowlabel1.setText("Label")
    edit = QTextEdit.new(dialog)
    edit.enabled = false
    ok = QPushButton.new("OK", dialog)
    ok.clicked do
      dialog.hide
    grid.addWidget(windowlabel1, 0, 0, 1, 3)
    grid.addWidget(edit, 1, 0, 3, 2)
    grid.addWidget(ok, 4, 3)
    grid.setRowStretch(3, 1)
    grid.setColumnStretch(1, 1)
    dialog.exec
    Save this to "dialog.rb" and run it this way:
    klayout -z -r dialog.rb
    That worked! Thank you Matthias!
