Generating a MouseEvent and using Qt_MouseButton
edited May 2015 in Ruby Scripting
I am trying to use the following line to generate a mouse event from
my unit tests:
mouse_click = RBA::QMouseEvent.new(
RBA::QEvent::MouseButtonPress, point,
RBA::Qt_MouseButton::LeftButton,
RBA::Qt_KeyboardModifier::NoModifier)
The Qt_MouseButton::LeftButton arguments are accepted as the correct type
for the QMouseEvent.new method, however a runtime error is generated:
TypeError: can't convert RBA::Qt_MouseButton into Integer
Since this is a Ruby method bound to C++ and cares about type, I assume
I have given the method the correct value, yet it complains about the
value at runtime.
I am using Klayout 0.23.9 built with Ruby 1.9.3 and Qt 4.8.5.
What am I doing wrong?
Dave
  • edited May 2015
    Hi Dave,
    This code actually works under Windows 7, using KLayout version 0.24-python-eval which uses Ruby 2.1.3 and Qt 4.8.2.
    As far as I know, this was changed in the transition from 0.23 to 0.24. The 0.23 version seems to use integers as Qt flags, so for example the following code works in 0.23.10:
    RBA::QMessageBox::Ok      # returns Ok (1024)
    RBA::QMessageBox::Cancel  # returns Cancel (4194304)
    OK = 1024
    CANCEL = 4194304
    RBA::QMessageBox::information(nil, "Title", "Text", OK | CANCEL)
    In 0.24, this was improved to the following:
    OK = RBA::QMessageBox::Ok          # returns Ok (1024)
    CANCEL = RBA::QMessageBox::Cancel  # returns Cancel (4194304)
    Strangely enough, trying to convert your example to 0.23 using integers
    RBA::QEvent::MouseButtonPress        # returns MouseButtonPress (2)
    RBA::Qt_MouseButton::LeftButton      # returns LeftButton (1)
    RBA::Qt_KeyboardModifier::NoModifier # returns NoModifier (0)
    MOUSE_BUTTON_PRESS = 2
    LEFT_BUTTON = 1
    NO_MODIFIER = 0
    point = RBA::QPoint.new(123, 456)
    mouse_click = RBA::QMouseEvent.new( MOUSE_BUTTON_PRESS, point, LEFT_BUTTON, LEFT_BUTTON, NO_MODIFIER)
    ...didn't work for me, I got a RuntimeError: Unexpected object type (expected argument of class QEvent_Type, got Fixnum) in QMouseEvent::new.
    Maybe there is a clue in the Qt Binding documentation, but I would recommend upgrading to 0.24 as this is probably going to become standard eventually.
    Regards, Chris
  • edited May 2015
    Ok, seems like I didn't try hard enough. This hybrid worked under 0.23.10:
    LEFT_BUTTON = 1
    NO_MODIFIER = 0
    mouse_click = RBA::QMouseEvent.new( RBA::QEvent::MouseButtonPress, point, RBA::Qt_MouseButton::LeftButton, LEFT_BUTTON, NO_MODIFIER)
    Strange. Still, I'd move to 0.24 if possible.
    Regards, Chris
  • edited May 2015
    Thanks Chris.
    This got me out of a quagmire. Your QMouseEvent.new() invocation worked in my installation.
    I've taken note of your comments about versions. I can recompile a later version of KLayout,
    but moving Ruby and Qt are problems to change in my company environment.
    I really appreciate your help.
    Dave
  • edited May 2015
    Hi Dave, hi Chris,
    I am sorry for that confusion. I have mentioned the reason in a different thread: QFlags are classes in 0.24 and no longer mapped to integers. That enables a syntax close to C++ and all the features that QFlags offers, but lacking the backward compatibility. This is because there is either a class or an integer argument. There is no implicit translation of integers to QFlags classes yet.
    Seeing the problems this causes, I consider hardcoding a backward-compatible data path.
    Thanks for bringing this up.
