It would be nice to have a module to be added in the menus to help us to calculate the density of a layer.
Thanks to this module : http://www.klayout.de/useful_scripts.html#cell_bbox.rbm
and this routine : klayout.de/forum/comments.php?DiscussionID=164
But, I don't know how to make a window to select a layer to calculate its density :(
OkGuy
Hi OkGuy,
here is some derived script that adds some "user interface". It computes the density on the selected layer and asks for the tile dimensions in a input dialog. It will also use the cell's bounding box to derive the tiling area.
This is hopefully some acceptable compromise. "Real" user interface are possible using qtruby or the Qt integration which will come with the next version.
I modified it to include it in the tools menu.
However, I did expected a figure:
Layer density = ..% of the selected area
How to calculate the area of the selected layer / the total area ?
OkGuy
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# DESCRIPTION: Compute area of selected shapes
# Run the script with
# klayout -rm density_map.rbm ...
# or put the script as "density_map.rbm" into the installation path (on Unix for version <=0.21:
self.title = title
self.shortcut = shortcut
@action = action
def triggered
@action.call( self )
private
@action
# $density_map = RBA::Action.new
# $density_map.title = "Density Map"
$density_map = MenuAction.new( "Layer density map", "" ) do
mw = app.main_window
lv = mw.current_view
if !lv || !lv.active_cellview
cl = lv.current_layer
raise "No layer selected to create the density map from"
input_layer = cl.current.layer_index
value = RBA::InputDialog.get_string("Tile Size", "Enter the tile size in micron (x,y)", "50,50");
if !value.has_value?
return
value = value.value
if value !~ /^\d*(\.\d*)?,\d*(\.\d*)?$/
raise "Expected a tile size (x, y) in micron"
va = value.split(/,/)
xw = va[0].to_f
yw = va[1].to_f
if xw < 1.0e-6 || yw < 1.0e-6
raise "Invalid tile size"
# Let's start ...
# Set up the environment:
raise "Density map: No view or no layout active"
# obtain the pointers to the layout and cell
top_name = lay.cell_name(top)
top_bbox = lay.cell(top).bbox
dbu = lay.dbu
bbox = lv.active_cellview.cell.bbox
xmin = bbox.left * dbu
xmax = bbox.right * dbu
ymin = bbox.bottom * dbu
ymax = bbox.top * dbu
# Start to collect the data:
data = []
# proceed row by row
# (for each row we use the multi_clip_into which is more efficient than single clips per window)
nrows = 0
y = ymin
while y < ymax-1e-6
# Hint: we need to clip all layers (clip does not support clipping of one layer alone currently).
cl = RBA::Layout.new
cl.dbu = dbu
# Prepare the clip boxes for this row.
# Note: because clip only works with boxes that overlap the cell's bounding box currently, we
# have to operate with a subset of fields to support the general case.
boxes = []
x = xmin
ncolumns = 0
colstart = nil
while x < xmax-1e-6
b = RBA::Box.new((0.5 + x / dbu).floor, (0.5 + y / dbu).floor, (0.5 + (x + xw) / dbu).floor, (0.5 + (y + yw) / dbu).floor);
if b.overlaps?(top_bbox)
colstart ||= ncolumns
boxes.push(b)
x += xw
ncolumns += 1
columns = []
ncolumns.times { columns.push(0.0) }
$stdout.write "Running row y=#{y}..#{y+yw} "
if colstart
col = colstart
# Actually do the clip
ep = RBA::ShapeProcessor.new
merged = RBA::Shapes.new
# Compute the area within area box
cells.each do |c|
# merge the shapes to polygons and compute the area
ep.merge(cl, cl.cell(c), input_layer, merged, true, 0, false, false)
a = 0
merged.each do |m|
a += m.polygon.area
# compute and store the density
a = a * dbu * dbu / (xw * xw)
columns[col] = a
col += 1
$stdout.write((0.5 + a * 100).floor.to_s)
$stdout.write " "
$stdout.flush
puts ""
columns.each { |d| data.push(d) }
y += yw
nrows += 1
if nrows * ncolumns > 0
img = RBA::Image.new(ncolumns, nrows, data)
img.pixel_width = xw
img.pixel_height = yw
img.trans = RBA::DCplxTrans.new(1.0, 0.0, false, RBA::DPoint.new(xmin, ymin))
if $density_map_image_id
lv.replace_image($density_map_image_id, img)
else
lv.insert_image(img)
$density_map_image_id = img.id
menu = mw.menu
menu.insert_item("tools_menu.end", "density_map", $density_map)
Hi OkGuy,
from the explanation you gave initially I thought you might be interested in the density map. At least that is what the forum entry is about. Could you be somewhat specific what exactly you require? Do you need the total density? Do you need the density map at all?
Even if you require the overall density it may be a good idea to compute a density map first and then average over the individual tiles. That avoids memory allocation issues with large layouts because the algorithm works on a tile-by-tile basis. You still need to enter a tile size which should be reasonably small (i.e 500x500 micron max). Please note that the chip dimensions are rounded to the tile size, to the results are most accurate when the tile size is an integer fraction of the chip size.
The code change would be to replace that piece:
by something like:
Sorry, for my bad explanation.
It works fine, even on a very large dimension.
Thank you very much!
OkGuy
I tried using it.
I get completely black map in all my attempts
When I modify macro to only report the total density, I get a result different than zero which seems to make sense.
So i don't understand why the density map is all black.
Itamar
Hi Itamar,
the script should print out the densities in percent on the console (if you run it in the macro editor for example). What are those numbers? Do they make sense?
If yes, then it's somehow related to the data mapping inside the image.
I think the problem is when doing density for via layers which have inherent low density.
When I ran it for poly i got a valid map.
Maybe it's possible to do the color scaling based on relative layer density and not based on fixed 0-100% density
This is the printout for VIA2:
Running row y=0.0..500.0 1 1 1 1 1 1 2 0
Running row y=500.0..1000.0 1 1 0 0 0 0 1 0
Running row y=1000.0..1500.0 1 0 0 1 0 0 0 0
Running row y=1500.0..2000.0 0 0 0 1 0 0 0 0
Running row y=2000.0..2500.0 1 0 0 1 0 0 0 0
Running row y=2500.0..3000.0 1 0 0 1 0 0 0 0
Running row y=3000.0..3500.0 1 0 0 1 0 0 1 0
Running row y=3500.0..4000.0 0 0 0 0 0 0 0 0
This is the printout for poly:
Running row y=0.0..500.0 19 19 31 33 29 34 36 0
Running row y=500.0..1000.0 19 24 20 40 27 45 42 0
Running row y=1000.0..1500.0 41 41 40 26 42 48 41 0
Running row y=1500.0..2000.0 47 51 51 34 51 52 49 0
Running row y=2000.0..2500.0 45 49 49 32 48 49 47 0
Running row y=2500.0..3000.0 46 49 49 33 49 50 47 0
Running row y=3000.0..3500.0 40 40 42 34 47 40 39 0
Running row y=3500.0..4000.0 1 0 0 2 2 0 0 0
Itamar
Sure that's possible. Just exploit the power of Ruby:
Thank you for the free platform and the discussion forum.
I have a problem where I need to compute density of different layers and then scale them and merge them into one image. Is this something you think the above code can be modified to?
Sorry I am a beginner with Ruby coding so asking for your help with the development.
Also, when I used the above code, the image is in grey scale, is it possible to convert to visible color scale.
Dheeraj
Something to help you get started.
The line that makes the image is
Look at the class Image under Public Constructors. The above is using the fourth version of the constructor listed there, because it has three arguments: ncolumns, nrows, data.
When you see "double[]" in front of one of the Public Constructor's arguments, it means that value should be an array, which "data" is.
Anyway instead of the fourth version of the Public Constructor, you want one of the other versions where you put red, green, and blue separately. For example for the result to be red you need first to make an array of zeros the same size as your data array, then to create the image with r, g, b arguments:
If you want it to be purple you can do:
To get a red image overlaid on a purple one, just call the first one img1 and the second one img2 or something. I haven't tried this but I guess it should work.
HTH
P.S. This code has been improved slightly and given a GUI: See TRT. After downloading it per the instructions, look under TRT menu > Layout > Density calculation.
Hi David,
thanks a lot - perfect intro :-)
I realize, that the image cannot be saved to PNG directly. If you want that you'll need to traverse the image pixel by pixel and generate a QImage object. This can be saved. I am overhauling the Ruby/Python API currently and I guess that interfaces to QImage and/or PNG/JPG files make some sense.
Thanks, Matthias
TRT code did not work for density calculations though:(
Mathias,
I have one more issue with using the code (just cumbersome).
Currently I am running the code by clicking macros and then execute. However, I would like the "layer density" tab to appear right when I open any layout. Could you suggest how to modify the code to achieve this?
Dheeraj
Hi, I recently used the calculation of the density map and i find that Region#area() calculate faster with this problem. This is my test code(python):
the result of my gds file is:
you can test the code with yourself by replacing the "gds_file", "pattern_layer" and top cell name.
Hi Garry,
Thank you for your inputs.
Eventually the best method probably depends on the nature of the layout and the pixel size. The most efficient method should be the tiling processor which provides an engine for doing operations on a regular tile grid.
The advantage of this approach is that it not only picks the best method but also supports distribution the computation on multiple CPUs.
I have code for this somewhere. I just need to dig this out.
Hi, Matthias,
Thank you for your reply. I really happy and look forward to getting your code.
Garry
The main difference I have foreseen between the 2 methods is that the first one (multi_clip) will take in account the shapes of the subcells, while the second one (region) will only consider the shapes of the topcell.
By the way, Matthias, Is there a way with region to check the shapes from the subcells ?
@garry: Here is a sample script using the TilingProcessor for density computation. It employs an Image object to store the density values:
@laurent: when you construct a region from a RecursiveShapeIterator, it will work an all shapes of a layer, including the ones from subcells.
I'm using the above scrip to get the density map which works great! However, as there's no way to export the image, I exported it as a string to a text file. It actually works, for the most part but I'm a little confused by the metadata within the "img" variable. Specifically:
mono:matrix=(100,0,1585.58) (0,100,-904.316) (0,0,1);min_value=0;max_value=1;is_visible=true;z_position=0;brightness=0;contrast=0;gamma=1;red_gain=1;green_gain=1;blue_gain=1;color_mapping=[0,'#000000';1,'#ffffff';];width=30;height=51
A lot of this is self explanatory, but I'm just looking for the positional data. I can tell the (100,0,1585.58) (0,100,-904.316) contains the size of the unit cell, as well as some other positional data. But what exactly does 1585 and -904 correspond to? It doesn't seem to exactly match the position of any of the squares.
Adam
Hi Adam,
"matrix" is a transformation matrix which transforms pixel coordinates (x=0,1,2..., y=0,1,2...) into micrometer values. The format lists the rows of the matrix. It's a 3x3 matrix for a general 2d transformation with homogeneous coordinates (affine plus perspective). "Homogeneous" coordinates are formed by adding a 1 as the third coordinates (x, y, 1) before feeding this into the multiplication with the 3x3 matrix. The concept is usually explained in terms of 4x4 matrices for 3d point transformations - for 2d, the z component can be thought to be 0 and the matrix is reduced to 3x3.
In your case, there is no perspective transformation and the third row is (0,0,1). The scale and rotate part of the matrix is (100,0)/(0,100) which means no rotation but a scaling with 100. This means the pixel dimension is 100µm. Finally the position of the center of the image is 1585.58,-904.316µm. This should correspond to the center your tiling arena. A little rounding may be involved because the arena will be fit an integer number of pixels.
In general, the string is rather an internal format used for serializing the image information in session files. It's likely that there are undocumented details and the format will be modified if necessary. If you need to export this information to another program, a better idea might be to use the Python API of the Image object and write the pixel values to a file in the format of your choice.
Thank you so much for the detailed explanation!
Hello Matthias,
This density calculation is very covenient for global density check in Win, but there is something strange about the results, when I do the density map calculation with insufficient RAM, the results is not correct compared with the results from Calibre nmDRC, unless I reboot my pc and try it again.
Best Regards,
Shijie
maybe you need to check the log for "bad_alloc" errors (File/Log Viewer).
Basically errors during the computation should make the density computation fail, but I cannot rule out entirely that errors get unnoticed. In this case, a tile may get skipped.
But this means your pixel size is pretty big and the number of polygons per pixel gets kind of high.
If possible, you could try to reduce the pixel size. Or you need to reduce the number of threads to avoid parallel computation. Or to plug in more memory and switch to 64bit if you're not already there yet.
Hello Matthias,
I'm looking into the "heat map part" and added the code below to create a kind of rainbow map ranging from blue (0) <> cyan <> green <> yellow <> red (1):
Is this the way to do it?
I noticed that the color map entry for 0.0 does not show up as blue, but it is black instead. Is that intended?
Is there some more information about color, lcolor and rcolor besides https://www.klayout.de/doc-qt5/code/class_ImageDataMapping.html#method15?
Cheers and enjoy the x-mas holidays!
Hi @tomas2004,
I'm afraid there isn't much more documentation than the provided one - apart from the code, which of course is also documentation. That's Open Source
Your data mapping is basically correct and 0 should show up a blue. Maybe you can save the image in KLayout's image format (XML) using "img.write(...)" and share a test case?
I can't confirm there is something wrong with the color mapping, but I see some issues when I enable to color corrections in that case (brightness, contrast, gamma). Maybe there is actually some bug. I have created a ticket: https://github.com/KLayout/klayout/issues/1959
Another side note: the values for the color map entries are normalized - 0.0 for low end and 1.0 for high end. Low and high end need to be se by "min_value" and "max_value".
Hello @Matthias,
Thank you for your script above, the one that produces a density Image. Would it be possible to explain the line below?
tp.queue("_tile && (var d = to_f(input.area(_tile.bbox)) / to_f(_tile.bbox.area);_output(res, d))")Why do you need to start with
_tile &&? What does it mean to do a&&between a tile Region_tileand a "code" in parenthesis? What language of "code" is it? Is there a documentation? Did you integrate a compiler in Klayout for this language?AIso, is there a simple way to export the resulting Image in order to view it elsewhere, for example with Gwyddion? (in order to see the value under the mouse pointer for example).
Olivier
