New to Python based KLayout, and trying to follow examples.
Why don't I see my p-cell in the layout? I want to instantiate the BASIC cell with some text. The code is shown below:
pya.MainWindow.instance().create_layout(0)
view = pya.LayoutView.current()
L = pya.CellView.active().layout()
txt_layer=L.layer(1,0)
topcell = L.create_cell("TOP")
param   = {"layer":txt_layer,"text":lum_lib_txt,  "mag":10}
txtcell = L.create_cell("TEXT", "Basic", param)
trans=pya.Trans.new(0,False,0,0)
lib = pya.Library.library_by_name("Basic")
pcell_decl = lib.layout().pcell_declaration("TEXT")
param   = {"text":"foo", "layer":txt_layer, "mag":10}
pv = []
    for p in pcell_decl.get_parameters():
       if p.name in param:
           pv.append(param[p.name])
      else:
          pv.append(p.default)
pcell_var = L.add_pcell_variant(lib,pcell_decl.id(), pv)
topcell.insert(pya.CellInstArray.new(txtcell.cell_index(),trans))
The code has a couple of flaws.
The basic problem is to properly create the layers and make them visible. Here is some working code:
I modified your code for a Basic.CIRCLE, and found un-expected behaviour.
After running, the cell shows up as "Basic.CIRCLE(l=1/0,r=0,n=64)" and I don't see the layout:
Code:
Then I check the parameters
and get the correct ones:
Then I edit the cell Properties, and click OK, and the cell updates itself and draws correctly.
For the Circle from Basic.CIRCLE, the radius to use for programmatic instantiation is "actual_radius", not "radius". This PCell has two ways of setting the radius: on through the entry box and by moving the handle. "actual_radius" is the one that is taken for computing the circle and it's the consolidated version of both input channels.
But if it's just about creating circles, use "Polygon.ellipse(bounding_box)". It's roughly a hundred times faster and leaner.
Thank you.
Hello Matthias,
I did not realize you had responded. Thanks so much for your help.
