in manual, about LVS:
compare
This method (compare will extract the netlist (if not already done) and compare it against the schematic.
It returns true on success and false otherwise, in case you like to take specific actions on success or failure.
It seems the command "compare" is used to compare(layout, old.cir)
sometimes, after I modified my schematic, I want to compare the new schematic (new.cir) to an old schematic (old.cir).
So can the command "compare" compare two netlists rather than layout-vs-schematic?
for example,
compare(new.cir, old.cir)
Hycmos
yes, that's possible. But not within the framework of LVS.
LVS is just a wrapper around the scripting API, so you can basically code a script which does this.
The problem is that there is no infrastructure for this application yet: no file format, no browser etc.
The LVSDB format keeps a lot of information for layout back-annotation and probing which is
not available in your case.
A solution is either to tweak the LVS infrastructure (which can't be done without code changes
at the core) or to rebuild a simple infrastructure for your purpose. The key element is the
"NetlistCompareLogger" which is essentially a listener receiving events (success, mismatch)
while the netlist compare happens.
Here is a simple implementation taken from the unit tests. It will just print results as compare
proceeds. You can basically tailor the output to your needs:
Sir,
Thank you very much for your patience.
I plan to study the code to understand the method.
hope I can implement this work.
Good luck
Please note I have added "puts comp.text" to dump the collected compare report.
get a script error:
undefined method `text' for #-RBA::NetlistComparer:0x0000000030d94c18-
can not run the line "puts comp.text".
But I can see you defined the function text in class NetlistCompareTestLogger < RBA::GenericNetlistCompareLogger.
Sorry, please replace the actual compare code by this:
(I cannot edit the code above as the editing period expired).
The code is just a sketch ... there is a lot more to say about tweaking the compare step. Please study the methods provided by Netlist and NetlistComparer for various options that can be used for this purpose. SVS is a new application. Please don't expect it to work out of the box.
Hi @Matthias
Do you have any way to ignore or set tolerance for parameter for SVS check?. two my netlists has a different width of device so it flag connection mismatch also. It should be show property mismatch only.
Thank you,
dai
Yes, that is basically possible. You can attach some criterion to a DeviceClass which tell the comparer whether devices are considered equal or not. If you skip a parameter in that definition it is not compared.
See here for details and a code sample: https://www.klayout.de/doc-qt5/code/class_EqualDeviceParameters.html
netlistis the first input netlist as I recall.Please note that such features may be subject to change. I focus on keeping LVS script stable, not the implementation details.
There is a "netgen" which performs any-to-any netlist compare.
Not easy to find although it's part of the efabless / opencircuitdesign
MAGIC-based toolchain (there are other "netgen" developments,
newer and unrelated, which Bogart the search engine results). As
I make it out, the results can be cryptic and not necessarily easy to
get a graphical display, of. But people make it work on LSI / VLSI
layouts from schematic and it seems netlist-source-agnostic.
http://opencircuitdesign.com/netgen/
Thank @Matthias.
Thank @dick_freebird.
