I have a puzzling behavior in which I try to manipulate some layout objects in a Python script. First I try to detect certain objects in a cell using
view = pya.Application.instance().main_window().current_view()
layout = view.cellview(0).layout()
cell = view.cellview(0).cell
for idx, layer in enumerate(layout.layer_infos()):
for shape in cell.each_shape(idx):
print(cell.name, shape)
The strange thing is that if I have a single box in my cell, it will be found for some layers, but not for some!?! I am sure I am doing something wrong, but cannot figure out what it might be. In the attached files, running the script on the found-file lists one file:
TOP box (-283953,-228147;283953,228147)
And in the other, nothing?! To my understanding, both files contain a box on the same layer, 4/0. So, in this example, the box is in the same layer, to my understanding. However, if I move the box to another layer in the not-found file, it can be found there too it seems...?
Thanks for any help!
Hello @ravn
I did a simple trial, it worked fine under 27.13 version, even caught the tiny one in layer 10.
Ah, found it. There is an error in my code. I must use the layer_indexes to get the correct number. This code works:
Thank you @Vincent Lin for helping tracking this.
Very good, thanks @Vincent Lin for helping.
I think your code lacks a line which fetches "idxs".
Actually,
layer_indexesandlayer_infoscorrespond. The "layer index" is not a sequential number as there are hidden layers (e.g. for the PCell guiding shapes) which are not seen in the layer list but have a layer index.Python should allow to iterate over both lists this way:
