I want to extract a layout composed of Mos whose NE is much greater than 1. The number of extracted SD and G regions is very confusing, which makes it impossible to match SD and the corresponding G. Their numbers are as follows
I can't determine which SD and which G belong to the same device, so the recognition of devices and calculation of parameters cannot continue. How should I solve this problem?
i have a idea, according to G traversal, the edge obtained by interacting is sd
lets try!
A sketch would be helpful
Usually, it's a good idea to focus on one G, then collect S/D close to it. But that applies to traditional planar MOS geometry.
In the general case, the strategy is to have isolated polygons as recognition features (G is a good candidate for MOS). Then pick one of that polygons and collect the touching ones. This gives you one device. I think this is what by your last comment.
