Hello Matthias,
Recently I study Ruby and try to understand more about K-layout base,
May I ask a question as a novice about " DCplxTrans " function when doing unit convert?
Ruby code works fine under right sequence as
RBA::Box * RBA::DCplxTrans
But get error if swap the position between box & DCplxTrans
RBA::DCplxTrans * RBA::Box # error
Seems both two coding are acceptable under Python ( no sequence concern ), not sure the error comes from Ruby special syntax ?
Vincent
Hi @Vincent,
A transformation is always put in front of "*" (think Matrix multiplication), so this is they way things work on Ruby:
The Python binding picks the reverse order as a fallback, so the opposite way works on Python too. But as this undocumented behavior may change, I'd not recommend that way.
Hello @Matthias,
Yes, it makes sense as you said, matrix concept helps to well-understanding.
Vincent
