Dear klayout-experts,
The following script works perfect if I add -b to run a batch execution.
But now I would like to keep the GUI open to review the results inside klayout.
Reason is that I run KL through an ipc channel in another tool providing 2 gds file names I'd like to xor.
I tried several ways to provide a script to klayout to start the exceution in GUI mode.
Any idea is highly appriciated.
Thanks in advance,
Andy
# Batch run: klayout -b -r test.drc -rd gds1=a.gds -rd gds2=b.gds
# GUI open but closed at the end: klayout -r test.drc -rd gds1=a.gds -rd gds2=b.gds
l1 = source($gds1)
l2 = layout($gds2)
layers = []
[ l1, l2 ].each do |l|
l.layout.layer_indices.each do |index|
info = l.layout.get_info(index)
layers << [info.layer, info.datatype ]
# collect layers
layers.sort.uniq.each do |l,d|
log "Running XOR between #{l}/#{d} .."
(l1.input(l, d) ^ l2.input(l, d)).output(l, d)
here is a version which will display the results in a third layout:
Run this script the same way you described ("klayout -r test.drc ..." without -b).
Thanks for your update, I got it up and running as expected by the designer.
Also congrats to the new release. With the major improvments introduced in 0.25x Klayout becomes an even more outstanding SW - Thanks for this.
Best Regards,
Andy
Matthias,
I have tried to modify your script to select the cells but my syntax is not accepted, although you suggest it in another post.
Where is my mistake ?
Laurent
