This is a suggested feature: if you want to preserve the labels of a layer and write them to
an output, there is no easy way currently.
Here is a workaround: the following patch - if applied at the beginning of a rule deck,
adds a "labels" method which works similar to the "input" method, except that it takes
labels.
The only operation allowed currently on such a layer is "output" which will copy the
labels to a new layer:
# Adds a new method to take labels from original layers
# and to write them to an output layer (not more than this)
# Usage is:
# labels(layer[,datatype]).output(...)
# or:
# source.labels(layer[,datatype]).output(...)
# Monkey-patch Shapes#insert to accept an array of anything
class RBA::Shapes
self.method_defined?(:insert_org) || alias_method(:insert_org, :insert)
def insert(*args)
if args.size == 1 && args[0].is_a?(Array)
args[0].each { |s| self.insert_org(s) }
else
self.insert_org(*args)
# Add DRCSource#label to supply a special layer
# with an array-of-texts payload
class DRC::DRCSource
def labels(layer, datatype = 0)
li = layout.layer(layer, datatype)
iter = cell_obj.begin_shapes_rec(li)
iter.shape_flags = RBA::Shapes::STexts
data = []
while !iter.at_end?
data << iter.shape.text.transformed(iter.trans)
iter.next
DRCLayer::new(@engine, data)
# Supply the first version of #labels
class DRC::DRCEngine
def labels(*args)
layout.labels(*args)
# Example: copy labels from layer 1 to 100, size polygons by 0.1:
labels(1, 0).output(100)
input(1, 0).sized(0.1).output(100)
If that's good feature, it can be added to future releases.
Enjoy,
