Python for gds read in and layer information output problem
edited May 2018 in Python scripting
Hi, I am a new klayout user and just start to use python to so come coding work.
When I open a new and empty .lym file, what code I should input to get my goal? for example, I have a gds file named 123.gds.gz, its path is in "C:\Training\".
So is there a way to use python to read the gds file and export all the layer name as a .txt file?
Best wishes
Muheng
  • edited May 2018
    you could write a.py file like
    layout = pya.Layout()
    layout.read('c:\Training\123.gds.gz')
    for ly_id in layout.layer_indices():
    ly_info = layout.get_info(ly_id)
    print(ly_info.to_s())
    then using klayout to load a.py like,
    klayout -zz -r a.py
    Dion
  • edited November -1
    Hi, Dion,
    Thanks a lot, I am using windows PC, not Linux.
    When I use ur code, it shows an error:
    line7: expected an indented block
    line7 is the code "ly_info = layout.get_info(ly_id)"
    Well, do u know what is the problem about that?
    BTW,can u give me ur email address? so I can cut a picture and send to you, then you can have more details about my problem. I think something is wrong about my operation.
    Muheng
    Hi Muheng,
    please use Markdown to format your code (four blanks in front of the line. Otherwise your code formatting does not become visible.
    And please make yourself familiar with Python.
    The code is:
    layout.read('c:\\Training\\123.gds.gz')
    Hi Muheng, if you want to code in Python I would use PyCharm - it tells you prior to running the code whether there are errors (not just grammer, also runtime). You can then use KLayout in batch mode and drive it from PyCharm.
    Cheers, Erwin
    Hi, Matthias and Ejprinz,
    thanks a lot, now the code works!
    I will keep on studying python and klayout
    Best wishes
    Muheng
    Hi, Ejprinz,
    I am using PyCharm to program python now in windows, one thing I am not familiar is the Klayout pya module.
    Usually on the top of the python code, we can type the database which u want to import, for example
    import xlwt
    or
    But when I open Pycharm, I think 1st I need to to let the Pycharm know that the library "pya", right? otherwise I think the code does not know the pya means.
    Well, do u know how to setup in Pycharm and let it know pya library?
    Best wishes
    Muheng
  • Hi Muheng,
    currently you cannot import pya as there is no such module. It's a function built into KLayout, so you need to work inside KLayout to get it. I'm working on providing such an external module, but it's only going to cover the geometry database part.
  • oh, OK, thanks, Matthias
  • Hi Muheng, I very much look forward to Matthias's work of having a database module which can be used from a normal Python, but until then, you can still use PyCharm but you have to set the interpreter (in PyCharm) to be a windows batch file with the following content:
    @echo off
    setlocal
    C:\Program_Files\KLayout\klayout_app.exe -b -r %1
    The debugger in PyCharm doesn't work this way but the syntax checking etc. does.
    Best regards, Erwin
