Dear All,
I try to find a way to mesh one layout file.
1) export a .poly file from Klayout;
2) use Triangle to mesh this .poly file.
The .poly file represents a PSLG, as well as some additional information. PSLG stands for Planar Straight Line Graph, a term familiar to computational geometers. The detailed is in the link:
http://www.cs.cmu.edu/~quake/triangle.poly.html
I think the key is how to get the .poly file from Klayout.
Anyone can help me?
Or How do I create one python script to do this.
PSLG is what you get from KLayout's polygons. But there is no output to the .poly format yet. I don't think this is difficult. Here is a starting point. This script prints the hulls (outer contours) and holes of all polygons on a given layer:
Dear Matthias,
Thank you very much.
I will study every line of your code to familiar with Klayout's Python API.
I try to create one tool to extract one layout's parasitic RLC.
The tool is very like other tools such as Finite Element Analysis etc
The tool will
1)get .poly file,
2)then use Triangle.exe to mesh this .poly file, get many small triangle cells,
3)then extract RLC
I have finished step 2),3) by Python Code. The .poly file is the final step.
I write .poly file manually before.
Now I need one .poly file exported from Klayout automatically.
I finish the Code(but it just works, It is very slower than your original code):
1) select all shapes, then 'Edit-Selection-Merge Shapes';
2) Run this script;
3) get the right .poly file.
but I can not output the hole shapes.
(the hole line write one point which is any point in this hole)
Add hole lines to show the holes
How to code to output the hole?
Thanks.
I got it.
All holes can be identified.
Thank Klayout's power functions!
so cool!
Below is my work. ( except the place where a red circle. But I can accept it)
Very good
Thanks for sharing.
BTW: in the first post I forgot to delete the Delaunay import - I use it to check the decomposition. But I found that it only works on convex polygons. To me this looks like a too severe restriction as to be useful. Maybe I missing an important point here.
Thanks to your great Klayout. I almost finish this tool.
I studied the Class Delaunay in scipy.spatial. It seems that the spatial's Delaunay is based on Qhull.exe. So I studied www.Qhull.org. Maybe, this Qhull is more powerfull than Triangle.exe. But I have no more time to study it, and The Triangle is a perfect tool to implement my work, I decided to use Triangle.exe still. Thank you for your Delaunay code, I learn another tool Qhull.
Only one remaining question:
How to get the text in one layer ( for example, 2/0 )?
In my tool,
Layer(2,0)=metal2;
Box in Layer(2,1)=port;
Text in Layer(2,1)=port's name
So I must get this Text to identify every port.
This Code can not get text.
Thanks.
BTW, Below is the tool GUI:
You can iterate the texts this way:
Thank you,
I finished my work.
I am not a programmer. To implement this tool I studied Klayout's API by myself. It is a hard work for me.
So thank you for your help.
Now the tool works well.
It extracts the layout's parasitic parameter up to 3 layers(M3/Via2/M2/Via1/M1) now.
Of course, It can deal with any numbers of layer.
It extracts the parasitic value very fast.
Now I use the macro to export mesh file.
The future work is to use python's pya to export it.
If using pya, the tools do not need to open the klayout.
Thank you again.
