Have gone through the FSi tutorial and docs, I have not
found anything much on the actual motions of running,
interpreting / viewing results and debugging scripts.
I think I follow the basics but I can't seem to get any
errors reported from this small layout and DRC script,
where there should be several?
1) The docs mention log and error files but I find none in
the project where I'm working. Where would these land,
by default? There is mention of a log window and that
this may not be open - so how to open?
2) I note that the Macro Development Window has two
ways to run a script. There's F5 run current script, and
there's Shift+F5 run script from current tab. I seem to
get no action from the former, the latter at least seems
to execute (throwing syntax errors when those are present)
but in no case do I get a result of error markers to browse.
It seems like nothing happens. So what is "current script"
and how do I set it and know what it is set to?
Hi Jim,
I see you're optimistic, so you just reserved 4 digits for the question count
Regarding log file etc:
Log files are not quite useful - currently they just list the execution times, not error counts
Logs can be seen in the log viewer ("File/Log Viewer"). You can put messages into the script which are then printed like this:
If you place a "verbose" statement into your script, the log will show the execution times too:
You can do the same for the report file.
