Hi sir,
Here was my code
I want to base on pattern in layer 86,0 . to create a cell instance into that location.
But it is don't work . could you please help to check where is wrong?
Thanks.
#########user need to input the cell name (UBM....)######
instance_cell = "UBM_feature"
include RBA
mw = Application::instance.main_window
lv =mw.current_view
out_cell = lv.active_cellview.cell
layer = lv.layer(86, 0)
main_window = RBA::Application::instance.main_window
layout = RBA::CellView::active.layout
dbu = layout.dbu.round(3) *10
subcell_index = layout.cell(instance_cell).cell_index()
layer.data.each do |sel|
if !sel.is_cell_inst?
shape = sel.shape
point=shape.dbbox.center.to_s
location=point.split(',')
locationx=(location[0].to_f)
locationy=(location[1].to_f)
out_cell.insert(RBA::DCellInstArray::new(subcell_index, RBA::DTrans::new(locationx , locationy)))
RBA::QMessageBox::information(mw, "Instance", "Make instance ")
here was the error message.
@jiunnweiyeh You should take the layer from the Layout object, not from the LayoutView:
Thanks , here is my update code , and it is not-workable.
could you please help ?
@jiunnweiyeh A don't see the layout, but I assume there is no cell called "UBM_feature". In this case, "layout.cell(instance_cell)" will return nil and this error will happen.
