Hi sir,
When I open a cell in fit zoom ,
sometime I can't viewable the pattern /cell in the windows.(cause the pattern size is small )
I have to zoom in and zoom in , then that pattern can been viewable.
I guess that some item in setup menu (display) need to conifrm .(But I don't know which one should be the correct one)
Can you help me for that?
Hi jiunnweiyeh
in the set up menu Display --> optimization option
there's a "drop small cells if" option, this option Klayout will tried to drop small shapes during rendering to reduce system load.
Unchecking this KLayout will not supress small objects.
That's right - but that option should be off by default. The default settings are in a way that you should always see at least one pixel.
