What is proper way to call first variant (method with parameter) of LayerProperties.visible
in Python, since it is attribute there, mapped to parameter equal to True
? Same goes for other similar LayerProperties
methods like xfill
, valid
, etc.
Ha, you caught me. That is undocumented
The method version is called "visible_" with a trailing underscore. So you can use:
Same should work for the other attribute/method overloads.
Hi, Matthias!
Thank you for explanations! It'll be really helpful to update documentation!
