Hi
I have 2 databases, each holding a metal/pad with labels.
I would like to match the labels in the two databases i.e. do the pads have the same label.
I get the 2 layouts by:
cell1= layout("@1").select("top") cell2= layout("@2").select("top")
Adding the connectivity
pad_A = cell1.input(604,0) pad_B = cell2.input(604,0) pan_A_label=cell1.labels(125,0) pan_B_label=cell2.labels(125,0) connect(pad_A,pan_A_label)
This generates an error message:
'connect': The layout has multiple top cells in Layout::top_cell in Executable::execute
Any idea to fix
End goal is to mark metal/pads with different labels
Casper
Hi Casper,
I assume that
@1
or@2
have multiple top cells as the message says.The problem is actually some kind of bug and should not happen as
@1
or@2
already specify a certain cell. I have created a ticket for that: https://github.com/KLayout/klayout/issues/1594However, even without this bug, you will still not be able to do that, as connectivity cannot be built across different layouts.
