Hi sir, as the attached GDS and figure.
do you have any idea for how to process the pattern as layer 86,0 to be the layer 108,0?
in the layer 86,0 , we have many non-smooth pattern , I want to cut down it as layer 108.
do you have any idea for that ?
below , I have some idea , I want to using edge length to be a key to process it
But it is not workable...
could you please help me?
pattern_psv1=input(86,0)
chamferLen=5
edges = pattern_psv1.edges
hEdges = edges.with_angle(0)
vEdges = edges.with_angle(90)
chamfer1 = hEdges.interacting(vEdges).with_length(0..chamferLen.um)
chamfer2 = hEdges.interacting(vEdges).with_length(0..chamferLen.um)
chamfer1.output(150,50)
chamfer2.output(150,51)
Hi @jiunnweiyeh,
did you try "smoothed"?
Like this:
This function removes the step, but generates a non-horizontal edge. Will this be acceptable?
Hi Mathias,
smoothed will not a good solution for this case.
cause the result as this picture is not better.
here was what my current code , I using with_angle to check 90 degree pattern then check the bbox size.
After that , I still have some of pattern need to process , I still finding if any other ways.
(other angle but some issue , our customer provide a polygon pattern it is not regular.
Thanks.
