Hierarchy Descent/Ascent
I am using this script you provided to descent into layout hierarchies:
lv = RBA::LayoutView::current
lv || raise("No layout opened")
sel_cv_index = nil
sel_cell = nil
lv.each_object_selected do |sel|
  sel_cv_index = sel.cv_index
  sel.each_inst { |i| sel_cell = i.inst.cell; break }
  break
lv.cancel
if sel_cell
  cv = lv.cellview(sel_cv_index)
  cv.cell = sel_cell
  lv.zoom_fit
This works nice, but I am also looking for a way to step back "UP" to the parent cell...
Can you help me here?
Martin
  • edited April 2025
    That is difficult in the general case, because there is more than one parent.
    But why not just using "Display/Descend" and "Display/Ascend"?
    They do pretty much what Cadence does if that is what you're asking for. If you don't like the default key bindings and prefer "X", "Shift+X", "Shift+B", just redefine them in "Application/Setup" "Application/Customize Menu".
    And before you come to the next question: Check out the "key binding targets" at the bottom of that list. They correspond to "Move" and "Clone" for example.
  • It was unkind of Brand X to make bindkeys
    for the same action, different between
    schematic/symbol and layout editors.
    Still trips me up after decades.
  • @dick_freebird I know, I feel the same :)
  • Many thanks Matthias, I was struggling with CTRL+A and CTRL+D because I was just showing "Levels 0 to 1" (to show cell-boundaries only instead of the entire cellcontent)...
    After manually incrementing the level by 1 each time I descend (or decrement for each ascend) it behaves more or less like Cadence.
    I think I'm able to use this as suggested by you...
    Best Regards,
    Martin
