You can see that the default pop up location always locate at the center of the Xsection, which always happen to be the important location that I want to view. In the script, I'm doing multiple snapshot so that I can check how the Xsection looks at different process steps. But since this popup always block the view, I have to move it away and then click the Yes button so that It can continue. But the next popup will again appear at the center location. Is there away to automatically adjust the popup position to a edge location, so that I can only need to click the YES button without the need to drag this to the edge from the center location?
thank you.
XSection is a separate project hosted here: https://codeberg.org/klayoutmatthias/xsection
But I don't attend it currently.
So as of now it is "as is", unless someone wants to maintain this project.
Basically it's the below pause method, but I'm not sure how to modify that. Tried using CoPilot to modify this method, but requires using QT or TK. But once I included QT, the Xsection disappeared from the "Tools" tab in KLayout... Could you give me a hint how these might be modified? Please give me a direction so that I may try it out.
thank you.
v = RBA::MessageBox::question("XSection snapshot", "New snapshot taken. Continue?", RBA::MessageBox::Yes + RBA::MessageBox::No)
