DRC - How to obtain the length of one Box from multiple Boxes
Hi
In layer1/0, I have many shapes, namely polygons and boxes. All the boxes are of the same size and they are all squares. How can I obtain the side length of a box, such as the side length of the box in the red frame?
  • edited July 30
    You cannot directly. DRC is for checking thresholds, not for measuring.
    You can iterate the objects in a layer:
    layer = ... # a polygon layer
    layer.each do |poly|
      .. do something with poly ..
    "poly" will be a DPolygon object (https://www.klayout.de/doc-qt5/code/class_DPolygon.html).
    The reverse of "each" is "insert":
    # creates a new, empty polygon layer
    layer = polygons
    # adds a polygon to that layer
    poly = ... # a DPolygon object
    layer.insert(poly)
    This basically allows you to create custom DRC functions. But those will not be very efficient as they are executed inside the script engine.
