Design size variation when using Save layout options
I have a design "test.oas" with a top cell that interest me "Top" and a bunch of other empty topcells.
I try to get rid of other topcells using SaveLayoutOptions, but I am then getting a very large design
if I run the following script:
ly=pya.Layout()
ly.read("test.oas")
lo = pya.SaveLayoutOptions()
lo.add_cell(ly.cell("Top").cell_index())
ly.write("test2.oas",lo)
ly.clear()
ly.read("test2.oas")
ly.write("test3.oas")
I have the following design sizes:
test.oas is 199K
test2.oas is 31M (too large file!)
test3.oas is 174K (what I was hoping to have)
I also tried to change oasis compression level
lo.oasis_compression_level = 10
but it did not change anything.
would you have any idea what I am doing wrong when using Save layout options?
  • Hi @jonathan,
    "test2.oas" is not an OASIS file, because the default format is "GDS2" in "SaveLayoutOptions". Use "set_format_from_filename" to establish the right format (https://www.klayout.de/doc-qt5/code/class_SaveLayoutOptions.html#k_88).
  • edited August 2025
    Thanks! This has solved the issue!
    also providing corrected code:
    ly=pya.Layout()
    ly.read("test.oas")
    lo.set_format_from_filename("test2.oas")
    test2.oas is 174K
    I have noticed that if I use
    lo.set_format_from_filename("file.oas")
    It also works, so it is not necessary to have the same name as the output file, however
    lo.set_format_from_filename(".oas")
    fails and cannot determine the format, but I think it could be a good upgrade to allow this?
    PS:
    I also noted the other solution:
    lo.format= "OASIS"
    and sorry for not reading API reference properly as the format info is quite well documented.
