Layers initialization failure
edited September 2025 in KLayout Support
Greetings,
Wanted to bring to your attention that when a KLayout "tech" folder has the below structure:
tech/
test.lyp -> 2/test.lyp
test.lyt -> 1/test.lyt
It fails to initialize the Layers with the corresponding message:
I understand that KLayout assumes that .lyt and .lyp files should be in the same directory but when this directory is managed by a Design Management Tool it can happen that these files reside in different folders.
  • Hi @charavan,
    So you mean that "test.lyp" is actually a symbolic link? If by Design Management Tool you mean Clearcase, it is not.
    The ".lyp" file can reside somewhere else than ".lyt", but the path is resolved relative to ".lyt".
  • Hello Matthias,
    The problem occurs when the files are checked-in, not when checked-out. When checked-in, the “tech/*.{lyt,lyp}” files are symbolic links, and the actual files they point to can happen to reside in different locations, when either file has been updated.
    In the example above, when you resolve the lyt path, the base_path equals “tech/1” whereas the lyp file exists under “tech/2”, so KLayout fails to load it. Thus, in this particular scenario, the fact that you always resolved lyp relative to lyt may cause layers initialization to fail.
  • So you're implying that the scheme works, if the files are real files, but not if the files are symbolic links?
    That may be true, because the effective location of ".lyt" then is somewhere where ".lyp" is not seen. But I recall that using the effective location was an explicit request from a different party who wanted to put their technology package into a different place as a whole.
    So what am I supposed to do?
    BTW: modern configuration management systems don't do this symbolic link thing. KLayout is not the only tool that needs to decide what to do with them. I wonder why you are using this system? I bet it cases trouble in other places as well.
  • As long as full path works, I'm good.
  • Hi Matthias,
    I think one viable solution would be to calculate the base path prior resolving possible symbolic links.
    Assuming we have the below directory structure as part of $KLAYOUT_PATH,
    klayout/tech
    the base path will be klayout/tech instead of klayout/tech/1. Then, you should be able to safely resolve both lyp/lyp and get their real files.
    The behavior was observed in another party who had the KLayout tech folder design managed. I cannot recall the software used, but it was one of the “known ones” and certainly, it was not an old version. My understanding is that they have updated the revision of the lyp file, and when they checked it in, the real file is stored in a different physical location (/1/ -> /2/)
    In any case, you don’t’ have to necessarily do something about it, especially if you think it will break things elsewhere. And certainly, we don’t want to change the requirement of having lyp/lyt co-exist under the same folder. However, maybe changing the way you calculate the base path would accommodate this scenario too.
    Thank you.
  • edited September 2025
    Hi @charavan,
    that raises the question what symbolic links and what not. The original problem was that the whole folder itself was a symbolic link, like
    klayout -> somewhere/klayout
    Now klayout/tech/tech.lyt would be (klayout->somewhere/klayout)/tech. That path is then not to be realpath'd while klayout/tech/(tech.lyp->1/tech.lyp) should be?
    That feels inconsistent. Resolve symlinks unless they are the last component of a path?
    No modern versioning system like git, but also older ones such as ClearCase, Perforce, Subversion or CSV use symbolic links. Likely because symbolic links are not available on Windows for example. Some Linux-rooted package managers like nvm or nix use symbolic links to build a link tree with specific program versions. But that would be more consistent with having a link tree like
    klayout/tech -> klayout/tech/1
    klayout/tech/1/tech.lyp
    klayout/tech/1/tech.lyt
    so the base path would work as is.
    Let me know if you more details about that specific versioning system. Currently, that requirement raises too many questions for my taste without providing some evident benefit for a larger user community.
    Maybe if every layer of the path-resolution was "bite
    sized" as a shall variable, the user might find a way
    do this abstraction.
    Personally I like full hard paths nobody can mess
    with, but I am not subject to CAD management
    or its dictates.
    KLAYOUT_TECH_HOME=
    KLAYOUT_TECHNOLOGY=
    $KLAYOUT_TECH_HOME/$KLAYOUT_TECHNOLOGY/...
    Some shell script intervening, executed by the klayoutrc
    could be even more sophisto? Clever boys might make
    their own startup which a project-start-script could
    preload. This was always how we set up Brand X, our
    corporate project management overlay would be
    invoked from a local shell script (made one time at
    project setup) which left shell vars all set up like
    bowling pins for the "real" initalization chain.
    Now let me dispense a little brain-worm for the devs.
    Day is coming, for multi-technology layouts (2.5DIC
    heterointegration) comprising plural chips. Library
    structure will need to "stick to the bound tech" (per
    library) and could be N libraries. Big Iron is on it.
    Capability to handle module-level products and
    MCM "IC-form" products might be better than a PCB-
    centered tool.
    This kind of thing will only get tougher for the "single
    tech" paradigm.
