Trace path bugfix #2201 now causes trace net to fail?
I raised an issue with trace path in https://klayout.de/forum/discussion/2810/trace-path-issue#latest. Thanks for addressing it in bugfix #2201. After switching from 0.30.4 to 0.30.5, unfortunately now "trace net" no longer works for me (in addition to "trace path" still not working). A similar behavior as I reported before now occurs for "trace net", where there is a prompt at the bottom of the screen "Click on a point in the net", but when I click, nothing happens and Klayout just returns to normal behavior (if I click a second time, it just selects the geometry that is being highlighted). This is true for somewhat complex nets. If I click on a very simple net (e.g. just one single floating rectangle of metal layer), it does trace and highlight it successfully. This seems to be an issue that occurs specifically going from 0.30.4 to 0.30.5, so I suspect it has something to do with the fix #2201.
  • edited December 2025
    I don't know what's happening. I need to check.
    Here is the follow-up ticket on GitHub: https://github.com/KLayout/klayout/issues/2234. That's the place to go. And I really would appreciate a test case and a description of your stack. Or if you did some testing before I release the code!
  • Hi Matthias, thanks for your response. I did not do any testing before the code was released. I just have a comparison of what happens with 0.30.4 compared to 0.30.5 as described above. My real case contains proprietary data, so give me a day or two to come up with a standalone test case that illustrates the issue.
  • Hi @footang,
    I have merged my latest changes which I think should fix your problems. Preliminary builds are available here: https://www.klayout.org/downloads/master/ (Windows, Linux). Disclaimer: these binaries are not signed yet.
    If you like, you can test the current solution and give feedback. If it works, I will be happy to release that in the next minor release 0.30.6.
  • Thank you Matthias! Apologies, after coming back from the Thanksgiving holiday here in US I had to work on other things and did not get you a test case as I had indicated. But I tried the (CentOS8) version in the master directory, and now both trace net and trace path appear to be functioning correctly. I presume it was something in the UI and how it communicated the points, and nothing with the algorithm of how the net/path was actually traced out. I will continue to try out different cases and let you know if I discover anything unexpected.
  • Very good. Thanks for the feedback! :)
    I fixed two issues mainly:
    • When the shape you clicked at was lower in the hierarchy, the shape was not identified correctly in most cases
    • "Inactive" shapes (such from layers not part of the stack) could mask the shape you clicked at. I changed it in a way that only shapes participating the stack are recognized.
    I think that both bugs were present already in earlier versions, but I did not investigate. Maybe some other changes made one of these cases more likely.
  • Thanks for the explanation! I would not have implemented either of those elements in a simplified test case. Only my true, complicated full design would exercise those corner situations. So I'm glad that you were able to figure it out.
