I'm looking for a way to limit the number of DRC results, either in a "target" or in "report" concept. The idea is I do not need to see all my violations, I just need to check the existance of certain violations (for further post-processing), and I'm tryingnot to use too much disk space...
I'm running the DRC in bathch mode.
Yulia
Hi Yulia,
there is no immediate way, but you can script something:
The lines between class .. end basically extend the DRC layer object with a new function that reduces the data to the given number of elements.
However, the full data will always be computed - so you save disk space, but not processing time.
Then, is there a way to stop the DRC when a certain number of violations is reached ?
Laurent
