Output to FastCap and FastHenry
edited July 2010 in General
A nice feature enhancement would be the ability to export layers to FastCap and FastHenry.
I think that this can be done with the Ruby scripts so maybe I will take a whack at it. If anyone else has already done this it would be great if you can share.
Oliver
  • edited July 2010
    Hi Oliver,
    is there any specification about the format required by these programs?
    I am not familiar with those myself.
  • edited July 2010
    Matthias,
    They are both open formats. See this link:
    http://www.fastfieldsolvers.com/links.htm
    FastCap has a particularly simple file format, but it would benefit from pre-tessellation.
    This would allow folks to model their GDSII files better.
    Oliver
  • edited November -1
    Hi Oliver,
    I had a brief look into the documentation but I am not quite sure about the tesselation issue. There seems to be a tool that generates a mesh for a rectangular geometry and create .qui files that you can include, but I understand that it's more common to generate the mesh directly.
    Is there any more material I could look at? In particular I assume there are some guidelines how to choose the mesh density or the tesselation strategy for example.
    I have to admit that the topic is new to me.
    Matthias,
    A parameter to control the mesh density would be nice.
    I would think that breaking things into rectangles would work well for GDSII files.
    Oliver
    Hi Oliver,
    I am trying to make myself familiar with FastCap and FastHenry. I wonder what to do with non-rectangular features - I assume that decomposing them into rectangles and triangles would be a good starting point.
    I'm aware this comment is from a while ago ... I'm currently working on finding a program to breakdown these non-rectangular features into the FastCap .qui format. Did you find a way to do this or is this an unsolved problem?
    Mike
    Hi Mike,
    no sorry - I did not pursue this thread much further. Decomposition into parts is available but I don't know the requirements of FastCap. I understood this is tessellation and not just decomposition. I assume that a dumb trapezoid decomposition is not really helpful.
    Any inputs?
  • Hi all,
    I don't know if this might help, but FastCap is integrated into another open source ASIC toolset: https://github.com/wrcad/xictools. Possibly, it may be an inspiration how to implement FastCap&FastHenry into Klayout.
    Michael
  • A better link is : https://github.com/yuchsiao/caplet :
    -. caplet_gds2geo is python script to change the .GDS file into a .geo file (ascii 3D file)
    -. caplet_geo has to be compiled (C++) and is changing .geo file into .qui that can be read by FastCap
    I succeeded to compile all the files, get the .geo file, ... but failed to get the .qui file :neutral:
    Laurent
  • Hi Laurent,
    thanks for the link. Just to confirm, the caplet_geo generates .qui files, you must specify "--type pwc" for "caplet_geo_cli" program or you can execute FastCap directly from gui. I tried it with FastCap from xictools.
    Michael
  • Hi Michael,
    Did you succeeded to make a proper C extraction from a GDS ? or someone else ?
    If yes, can you share some example files (GDS, qui and spice file) ?
    It seems that xictools is the software to use ...
    Laurent
  • Dear all,
    thanks for the pointers.
    FastCap and FastHenry integration / interfacing is on my to do list. However, as of now, I have not taken a deeper look into that topic yet. I feel that in order to be useful, some integration on a lower level is required - specifically within the netlist extraction framework.
  • Hi Michael,
    Laurent
  • Automated preparation of input files for field solvers like FastCap or FastHenry sounds like a fun and useful functionality.
    However, I have a question - what would be the main usage model of this functionality?
    Where does it fit, in the spectrum of tools, on one end of which is a fully automated approach (used in IC design world), and on the other end - fully manual, hand-crafted (one time) preparation of the input and running the simulation?
    In IC design world, people use parasitic extraction tools - very sophisticated, heavyweight, powerful tools, supported by big EDA vendors, foundries, PDKs, etc. They fit well into the IC design flow, and rely heavily on LVS (output form LVS is an input for parasitic extraction).
    They are fully automated (once someone - a CAD or methodology engineer - sets up the flow), and perform their job with a click of a button.
    They are very expensive as well (one license may cost tens and hundreds of thousands of USD).
    On the other end of the spectrum - various field solvers, many of them - free.
    The input is tedious and time-consuming. The tools many not be very stable and robust, and may not have a good customer support.
    These tools are used relatively infrequently, and/or in situations where time is not a priority (time to market, engineering time, etc.).
    What would be the scenarios and usage models for the discussed automation of input data preparation, from Klayout, to various field solvers?
  • edited December 2022
    Superconducting quantum computer designer here. We need capacitance calculations for our microwave design - most of the parameters in a typical quantum chip, like the qubit capacitive energy and coupling to readout resonators and antennas are actually determined by quite simple coplanar capacitances calculations. FastCap is an academic standard, however I see that KQCircuits pursue another direction of Elmer open source simulator. https://iqm-finland.github.io/KQCircuits/user_guide/simulation/gmsh_elmer_export.html# Maybe because down the road it will do full transient EM field simulations, but then openEMS looks much more mature. They provide an important integration with gmsh, which is probably a better approach than reinventing the meshing problem - a point of crucial importance for every simulation. For example, next step will always be fine-meshing at sensitive design spots of high field concentration.
    To summarize, integration with FastCap would be very useful for my community, but to be properly done it requires mesh control and visualization.
  • @srjmas Thanks for your thoughts. I am aware that this feature is useful, but I am lacking the bandwidth to take care of this.
    I assume it is possible to integrate these tools with the help of some scripts. I'd appreciate contributions in that area.
  • There are so many ways that you can use to perform capacitance simulation ("extraction") for relatively simple layouts, both free, or affordable, or commercial and expensive - but they may already be available to your teams designing RF, MW, or designing Si chips that control qubits.
    These can be static simulators, like Q3D (Ansys), or Rafael (Synopsys), or E solvers like EMX, Raptor, PeakView, HFSS, etc.
    There is a nice affordable (I think) solver EZMod3D from this company:
    https://easii-ic.com/en/ezmod3d/
    You should find the right spot for you - a free version, but you will spend a lot of time preparing input, parsing output, tackling with the mesh and accuracy, etc.
    Or pay upfront and get stable trustworthy reliable commercial tool.
    Depending of what you value more - your company money, or your time.
  • Thank you, indeed I found my access to a Q3D. Thinking of it, most probably proper simulations are beyond the scope of a layout tool. And for the interest of the open source community - KQC export scripts to Elmer looks as good a solution as any.
    Actually, there are 2 kinds of parasitic extraction : a precise one for RF, any LNA or antenna needs a precises R and C extraction, maybe in 3-D. But for the digital place&route a less precise extraction but fast R-C extraction will do it. The simulation accuracy are definitely not the same ! and so the models, and so the R-C extraction ... fastCap and fastHenry are in the first category with a lot of calculations. The second category is more based on tables that describe the wires with less calculations ... as for the simulation ;)
    Synopsys has its explanation here : https://www.synopsys.com/glossary/what-is-parasitic-extraction.html
    StarRC is based on Look-Up tables : it could be a target for KLayout - but which look-up tables ?
    QuickCapNX is a 3D field solver for RF
  • MaxMax
    edited January 2025
    There was a post on LinkedIn earlier this week, announcing a parasitic extraction tool within Klayout (based on FasterCap and other FOSS tools).
    This post was quickly taken down.
    I guess, that post was premature.
    Matthias - can you share, what's the latest on parasitic extraction in Klayout?
  • Stephen Whiteley of Whiteley Research Inc. has open sourced his design tools. They support superconductors and various simulators mentioned above. http://www.wrcad.com/
