New installation - KLayout doesn't run on macOS Monterey (Intel)
  • edited February 2025
    Hi @SRF,
    1. HW-klayout-0.29.6-macOS-Monterey-1-qt5MP-RsysPhb311.dmg
    2. ST-klayout-0.29.6-macOS-Sonoma-1-qt5MP-RsysPsys.dmg
    The current macOS build4mac.py build system does not officially support Monterey.
    However, I hope it still works.
    Kazzz-S
    Edit 2025-02-23:
    If you want to use the ./build4mac.py -q qt5macports -r mp33 -p mp312 build command (Fully MacPorts-flavored build), edit macbuild/build4mac_env.py as below.
  • Hi @SRF,
    1. 6A. Standard build using the OS-bundled Ruby and Python with MacPorts Qt5
    2. 6B. Fully MacPorts-flavored build with MacPorts Ruby 3.3 and MacPorts Python 3.12
    Kazzz-S
  • Hi @SRF,
    I recently upgraded my development environment to Sequoia 15.5 + Xcode 16.4 + VMware Fusion 13.6.3. See this ticket.
    I also noticed that the view count of this post increases gradually.
    To reconfirm again that the source code build in Monterey is still possible, I attempted the two builds for KLayout 0.30.2 with the latest MacPorts packages.
    Kazzz-S
  • I've noticed that the number of views for this post is still gradually increasing.
    To reconfirm again that the source code build in Monterey is still possible, I attempted the two builds for KLayout 0.30.3 with the latest MacPorts packages.
    I uploaded two DMGs here for the community's reference.
    Kazzz-S
  • I have made another attempt to build version 0.30.4 on macOS Monterey (Intel).
    I have uploaded two DMGs for the community's reference, which you can find here.
    Unfortunately, the latest macOS version, Tahoe, no longer supports my 13" Intel MacBook Pro (2019 model).
    The machine's life is also nearing its end. :-(
    Kazzz-S
  • I made another attempt to build version 0.30.5 on macOS Monterey (Intel) to see if the overhauled build system for ARM64+Tahoe also works on Monterey.
    Kazzz-S
