I'm running klayout 0.21.11 on Windows 7 using the installable version, and I've been playing around with scripting.  RBA seems to work fine, but when I try to run any of the QtRuby examples, they fail with the error 'no such file to load -- Qt'.  Is the qtruby library supposed to be included with the klayout installation, or does this need to be installed manually?  I don't see any qtruby-ish files in the lib folder of the klayout installation.  I assume this lib folder gets used by the klayout ruby interpreter, not any system ruby lib directory.  If this does need to be manually installed, it would be helpful to add a note in the docs.
I provide a very basic ruby installation along with KLayout for Windows. It contains the basic packages only. On Linux, KLayout can make use of the Ruby installation on the system which can easily be extended with many packages, including qtruby4.
Apparently there is a qtruby installer for windows (http://vision.eng.shu.ac.uk/mmvlwiki/index.php/Qt4-QtRuby_installer_for_Microsoft_Windows). But that one is neither fitting the Qt version I use, nor is it providing a solution for Microsoft's compiler or Ruby 1.9 which is the basis for the 64bit version.
It's possible to install the gem system along with KLayout but I guess it won't help. It will also rely on somebody providing the binary objects.
Bottom line is that on Windows there is no qtruby4 right now. I am currently playing with various options either to get qtruby4 going or to provide a substitute. But right now, I don't have a good solution.
The gem contains among other things a Qt.rb file and a qtruby4.dll library. Qt.rb just contains the line "require 'qtruby4'" which I guess is supposed to load the dll, but when I try to import the Qt library in an rba script, I get an error stating 'no such file to load -- qtruby4'. I assume this means the library is incompatible with the ruby version, but as far as I can tell it is supposed to be compatible with 1.9.x.
If you have any thoughts about what to try next, please let me know. I'm still a ruby newbie, so I don't have much experience diagnosing these sorts of things, nor a good understanding of the issues around binary library compatibility. I'd rather not set up a build environment to build qtruby myself, but that might be the only solution.
It's possible to build KLayout with Ruby 1.8 as well, but that will exclude 64bit on Windows. As I mentioned before, I am thinking about a substitute solution, but it's too early to promise anything.
