I would like to know if the inverted function of "Selected Merge Shape" is well implemented in Klayout ? For instance, I want to separate a selected shape at the current layer (polygon or box) into 2 new shapes edge to edge (polygon or box). This shape separation requires to add a drawing tool like a cut line. In this function is'nt available, could I realize it by a Ruby script ?
Best Regards
Jean-Yves
Hi Jean-Yves,
The only way to emulate that currently is to use a mask shape on some arbitrary layer covering one half of your original shape and perform a AND and a NOT boolean operation, both to different new layers. The first operation will select one half and the other operation the other half. If you then select all shapes on one of these layers and change their layer to the other layer, you will finally have both halves on the same layer.
If that is too difficult, it is possible to automate the AND/NOT steps in a Ruby script, but the basic principle (a mask shape) will remain the same.
Thank you for your answer. I tried your solution by creating an additionnal cut layer followed with a NOT operation. It works perfectly !
Thank you
Jean-Yves
Is it possible to make a boolean layer operation when Trace Net is still running ?
In this case, Klayout returns a Bad Allocation error message.
Thank you
Jean-Yves
hereafter some ways in order to understand the bad allocation memory error.
When using the boolean layer menu available with Klayout, it's seems the processor shape pointer isn't destroyed after the operator execution. The memory used grows after each run.
I tried also a boolean not operation between a box created from a cut layer and a single layer (> 250 Mb). Klayout returns in this case also a bad allocation memory error.
Best regards
Jean-Yves
Hi Jean-Yves,
it should not be possible to run a boolean operation while the net tracer is running. The database is not designed to support parallel reading and writing. That might explain a memory allocation problem. I'd consider it a bug, if it's possible to run the net tracer in parallel to the boolean operation.
Another thing is, that the boolean operation is not quite efficient on hierarchical layouts. It's basically a simple flat implementation and suffers from hierarchy expansion. If you just need to use it for separating shapes, I'd suggest to select the shape to separate and then (using Shift+Mouse click) the mask shape and perform the NOT with the "Edit->Selection->Subtraction" menu, which operates on the selected shapes only.
