Hello everyone.
I have a very basic query on DRC.
I am trying to write some DRC commands for my layout but couldn't find a way to this issue. I want to see where are this kind of misalignments in my whole design.
I am sorry to bother if this is a very basic problem. Thanks a lot in advance.
Thankfully,
Bishal
Hi Bishal,
Maybe you can detect such cases with edge-length checks:
@Matthias thank you for the answer. It worked for me.
Additionally, I would like to ask one more query related to same issue.
Now I used:
short_edges =LayerSiN.edges.with_length(1, 100.nm)
output(short_edges, "Alignment","Devices misaligned")
This gives me DRC result in a new window. What should I do if I want a polygon in different layer plotted at the misalignment area. Not just this misalignment case, maybe in case of space too.
Thankfully,
Bishal
You probably need to read about the functions
layer.polygons()andlayer.output()in the documentation: https://www.klayout.de/doc-qt4/about/drc_ref_layer.htmlNote: Your second graphical example is very different from your first graphical example, which brings confusion about what you want.
@ocasta , Sorry for the confusion.
Actually what I want is, I can run the DRC and see the results. But it would be much better if I could make some polygon showing a specific type of errors like misalignment, space etc.
For the misalignment, it should look something like this:
So I want to make those white polygons at misalignments so anyone else can understand that there is misalignment just be checking that specific layer.
I believe this clarifies my intention. If there is still something more, I will be more than happy to share.
Thank you for the guidance.
Hi photonicsbishal,
you mean you want to generate as new layers?
Basically DRC can output to a marker DB (into the marker window) or to new layers.
For creating a marker DB use:
For creating markers on a new layer (here: 1000), use:
or give it a name (will not save to GDS):
For the error marker generation here are some suggestions:
Thank you @Matthias ,
This is exactly what I was looking for.
Thanks a lot.
Hello @Matthias,
I am running the script you provided and faced with this issue.
When I try to execute DRC to marker DB, it is working fine. But whenever I try to write it to layer, this error is popping up. I hope to get some guidance from you regarding this issue.
My script:
This script works and shows result in marker DB
report("DRC_report") Layer1=input(1,0) Layer1.space(300.nm).output("Si_space","Si minimum space violation; min 300 nm")But if I use, the below script, some error occurs as in the image attached which I am unable to decode.
report("DRC_report") Layer1=input(1,0) Layer1.space(300.nm).output(200, 0)Error:
@photonicsbishal
When you want to output to a different layer (here: 200, 0), you need to drop the "report" line.
You can however switch dynamically:
