I've been running a simple DRC on a .gds file and right now the output is exported as a new .gds file:
source("./SingleDie.gds")
target("./output.gds")
lyr1 = input(3)
lyr1.merged().space(2.um).polygons().merged().output(902, 0)
Is there an easy way to send the results back into the original file (SingleDie.gds) as a new layer rather than generating a new .gds file?
You're running the script in batch mode, are you?
I assume you don't want to overwrite the original file (this is bad style IMHO), but you want to add a layer to the original file rather than producing new layers only.
There is a trick to do this: Without "target" layers are sent to the source layout in "output". You can then use "source.layout.write("...")" to write the enhanced layout to any file you want.
Like this:
BTW: you should not need "merged()" before "space" ("space" should imply this). Have you found a reason to use the first "merged"?
That worked perfectly! Thank yo so much for your prompt and helpful answer! I knew there had to be a simple solution.
Well, I didn't write that code for the DRC myself and it appears to work just fine without merging before the DRC so looks like it's not needed.
Question - if running interactive, how would the output command differ? Thinking that the "source" command up top would be implicit (present view / "panel") and so maybe the output command doesn't want to refer to that; maybe just
layout.write("output.gds") ?
Now I would like to know about file path syntax, for both Windows and Linux, to assert that the output goes somewhere besides ~/Klayout. For example
C:\Desktop\klayout\DRC_Test1
and
/mnt/Data/projects/klayout/DRC_Test1
Like, are quotes enough to make Windows backslashes digestible, or does each backslash need to be escaped, etc.?
I haven't been able to find, so probably haven't gotten my script-dabbling to produce an output (having not much luck doping out the debug operation or what its complaints mean. That there would probably be a big HowTo help... an "error bestiary" often being more useful than pages of regExp without real examples.
Hi Jim,
please see my comments of the previous post too ... I'm digging through the recent bunch of posts (somewhat made people post all their questions right before Halloween - is this supposed to be scary?).
The syntax in general is Ruby, so you have to use double backslash for a single one. But forward slashes should work too. Anyway my last comment mentions a way to use a computed path without the need to put in a specific one.
There are many Ruby tutorials out there: for the string literal syntax for example you can take a look at: https://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Literals. For details about the File class used for the computed paths see: https://www.tutorialspoint.com/ruby/ruby_file_methods.htm
