I'm getting an error 'Invalid rotation angle (450 is less than -360 or larger than 360) (...)' on a file. I'm not sure the Gdsii stream spec limits the ANGLE to -360 to 360? (not in the spec I have). Anyway, maybe (dis)allowing this as a GDSII reader option or so?
Hallo,
this is actually just a warning. It indicates that there may be something weired going on, but KLayout will reduce the angle to a range between 0 and 360 degree. I think it is worth mentioning strange angle values because that may indicate some other issue (i.e. a corrupt file). Still the file can be perfectly valid.
I wanted to add that for text rotations, the angle is limited to multiples of 90 degree. The GDS spec allows any angle.
Hallo,
you're right, it's a warning for texts but an error for instances.
I'll change it to a warning in the next release.
If you're able to build KLayout, you can replace the error around line 894 of dbGDS2ReaderBase.cc by a warning:
instead of
