Hi, Matthias!
I encountered problem with restoring session from command line (layout files are not loaded) when directory name contains + (i. e. klayout -u <absolute path with + sign> -d 10). Session contains relative paths to layout. I traced root of problem to Session::make_absolute call from Session::restore. URI::to_string always escapes plus as well as other special characters even if URI is plain file path, so resulting absolute path is incorrect. My naive workaround is:
  if (! m_path.empty ()) {
-    res += escape (m_path);
+    if (res.empty())
+      res = m_path;
+    else
+      res += escape (m_path);
Probably there is better way to deal with URI than that.
Problem exists in 0.26.4 and 0.26.10.
Same problem happens when session is restored in GUI or relative path is used, i. e. KLayout started from path with
+sign and relative path in command line doesn't contain it.I'm not aware about design intent, but it'll be good idea to treat path in command-line parameters and internally constructed ones in same way. Currently former is taken in raw form without converting to URI when later are converted to URI.
Yes, I can reproduce the problem. Thanks for reporting that issue.
I have created a ticket for this: https://github.com/KLayout/klayout/issues/733
