I have two basic questions that I would really appreciate if someone can answer.
I want to load a layer property file (.lyp) to my layout through the Python script that I have already created for that layout, and connect the layer properties in that file to the ones I developed using the script. Is there a simple way to do this on Python scripts?
I believe in order to connect the layers in my layer property file to the layers in the layout, I have to use the same index in my codes, right? I mean, for example, I have a layer named "METAL" in the layer-property file that has an index of (1,0). So, if I use the same index (let's say (1,0)) in my codes, basically they should be connected after I run my codes and load the layer property file. Is this the right way to do this or is there any more convenient way?
Thanks in advance.
Mo
Hi, Mo!
See
load_layer_props
methods of LayoutView class.I have a question, which I can't recall whether
I've asked directly.
That is, is there a logging of the interactive command
stream, from which series of user actions turned into
native commands could be "harvested"? Maybe even
in a form directly mappable to these "class items"?
I think back to my years using "Brand C" and how
often we'd make SKILL widgets by grabbing a
snippet from the CDS.log file. It could be neat to have
the ability (or maybe we do) to make macros from
GUI actions, either in-the-moment or by harvesting.
Of course I have no idea whether the GUI driven
actions have any intersection with Python or Ruby,
as well as the question of whether they are logged
(usefully).
@dick_freebird
The classic way of code golfing
looking through the CDS.log or the icfb
@MoBe
Hi Mo,
Yes you can define this in your layer tech file
The following is an example to change layers to have names.
I have placed example copy on github here
https://github.com/hgroller/tech_layer_purpose
Just copy and paste and save as tech.lyp
Thank you @EugeneZelenko and @tagger5896 for the explanation. Great solutions!
