I noticed on most recent version, when I instance a cell in a new cell, l can change the cell's drawing on the higher hierarchy. This new feature makes the basic cell un-secured. Is there a setting that l can disable This function? I prefer not be able to change the cell on a higher hierarchy to avoid unintentional change.
@duanhua That's not the new version. Please check if you have enabled "Select Top Level Objects" in the "View" menu. With this option enabled, you can only edit objects sitting in the current cell.
