Hello, Matthias
Good day,  I wanna do an enclosing_check between two boxes, then print the shortest space in each side on console
or do something else..  but I not clearly get the method of it, so comes below silly code..   I am not sure it can be done by python
or not, could you give me some simple hints ?  Thank you !
Region(A).enclosing_check(Region(B), 1000, True, Projection, 0, 0, 0, True,False,False,False)
Sorry, I posted this new discussion under " Verification " when reading some case,
if so, there will be no topic categories to choose. Please help to re-align to " Python code " if possible, thanks..
No worries - discussion is moved.
Regarding your question: the problem is that enclosing is not measuring. The goal is first of all to flag locations where a minimum condition is not met.
However, the results of that operation is a so-called edge pair collection. The edge pairs consist of two edges flagging the involved edges. You can basically extract the distance from them. There is a related discussion about this topic here: https://www.klayout.de/forum/discussion/2109/getting-more-information-from-a-drc-call#latest.
Hello Matthias,
After trying, I found in Ruby:
Region::Metrics Projectionis equal to python
Region.Metrics.Projectionit works ! I think it's time for me to study " Ruby " thanks~
