We are trying to upgrade ruby version from 1.8.7 to 1.9.3, and encounter a strange problem when running dump_texts_file.rbm .
With ruby 1.8.7, the coordinate could be output precisely, however in 1.9.3, it would output a special number.
For example:
1.8.7: TEXT1 (89.0,231.2)
1.9.3: TEXT1 (88.99999999999999,231.19999999999996)
Is it our ruby 1.9.3 issue ?
The partial code of dump_texts_file.rbm
  lv.each_object_selected do |sel|
    if !sel.is_cell_inst? && sel.shape.is_text?
      text = sel.shape.text
      p = sel.trans.trans(text.trans.disp)*lv.cellview(sel.cv_index).layout.dbu
      file.puts("#{text.string} #{p.x} #{p.y}")
chhung
Hi chhung,
apparently Ruby 1.9.3 uses a different precision when converting float's to string (or the underlying C library does it differently).
Anyway, you can fix the problem using a specific format and the % operator:
this example outputs the numbers with a maximum precision of 12 digits which is the number of digits I am using usually. It not too much so that rounding errors are suppressed and it's not too little, so we don't loose precision.
Thanks for the new code, it solved our problem and works fine.
Thank you~
Best Regards,
chhung
