Hi @Matthias
I saw "split_gate" feature(let us reduce gate) in klayout new version. It is very usefull
I think it will be more usefull if we have this feature in netlist object also. Because schematic designer use multiple factor like below some time:
So if we use split_gate for netlist so we need run this feature for netlist of schematic also.
Thank you!
dai
Well crafted SPICE models will give you different (subtly)
outcomes from (say) a 100/0.18 and a (10)10/0.18 FET.
Your verification ahould not ignore or obscure this if any
analog matching interests are involved. Probably want to
make this a "switch" in the LVS (where you can decide
whether or not to allow) rather than in the extract, where
it may get "baked in" but invisibly so.
Hi Jim,
"split_gates" is not available for schematic, but you can easily add this feature:
Regarding extraction (and compare I assume) of the finger ("m") parameter: I think that can be added, but I see a number of open questions - e.g. how to add two devices with different widths.
Hi @Matthes ,
It works perfectly
Thank you,
dai
